07-30-2020 15:19 - edited 07-30-2020 15:22
My Ionic died 2 days ago. Put it on the charger and nothing. Have tried the reset with 2 buttons and 3 buttons and it will not turn on now for anything. Have had it charging 2 days now and can't get it going. Any help will be greatly appreciated because I don't know what to do now.
Best Answer07-31-2020 09:58
07-31-2020 09:58
Seems to be a common issue, several others and I have the same problem. Fitbit’s fix is to give you the privilege to buy another watch, which will probably also break right after warranty.
