10-04-2017 12:37
10-04-2017 12:37
Got my new Ionic on Sunday, have had no problems with it so far until today. Everything was working fine, went for a walk, and in the last couple hours the ionic screen won't activate when I raise my wrist. I haven't changed any settings today and I've restarted the device. Haven't done a factory reset yet, that's a last resort. Any ideas on how to fix this?
05-22-2018 16:44
05-22-2018 16:44
It has nothing to do with swiping from left to right or right to left. Hold the left button in and hold you will have two choices the wake settings and the notification settings, move the wake setting from manual to auto
06-18-2018 19:05
06-18-2018 19:05
The auto is wearing my battery out. And your tip brought up the awake screen so could change it back to manual. Thanks
Best Answer06-26-2018 20:19
06-26-2018 20:19
Wilsha, me thinks your post is in appropriate! I have been trying to figure out how to get it back to auto and Willy’s advice was the only one that worked! So there!
Don’t be so judgmental ……
Thanks Willy!!!
07-18-2018 20:32
07-18-2018 20:32
My problem is slightly different, in auto mode, it will not constantly show the clock when I do my usual motion of twisting my wrist [less of an arm raise]- I often am in meetings, and do not want to have a big gesture to have to glance at my watch, is there a way to adjust the sensitivity ? Or, am I stuck with using this in manual mode ? This is not what I wanted in a watch ! I have had 2 older fitbits, most recently a surge and they worked fine ...
Best Answer07-19-2018 00:18
07-19-2018 00:18
Best Answer08-08-2018 15:36
08-08-2018 15:36
Tried everyone elses suggestion but nothing worked. Yours was the simplest and worked. Thanks
Best Answer08-08-2018 23:23
08-08-2018 23:23
Best Answer09-20-2018 13:06
09-20-2018 13:06
I can’t get my screen to wake when I raise/rotate my wrist. And when I swipe right to try find where I can set the screen wake to auto, nothing shows up. And when I swipe left it just brings me to the apps.
Many suggestions on what to do?
Best Answer10-03-2018 23:14
10-03-2018 23:14
I turned mine off and when I turned it back on it gave me the option to turn the function back on.
Swipeing right does nothing on mine.
Best Answer10-04-2018 11:45 - edited 10-04-2018 11:45
Hello @alokeson and @talogon, it's good to see you around in the forums.
Thank you for sharing what you've been experiencing with the quick view option on the Ionic. You should be able to activate this feature by pressing and holding the left/back button of the Ionic. The Wake screen option should be right at the top.
If you're still having trouble with this, make sure you've tried a restart process for your watch and that you've also tried to turn it off and back on, as it was mentioned in this thread previously.
I hope this helps, keep me posted.
06:10
08:16
JuanJoFitbit
10-13-2018
06:10
08:16
JuanJoFitbit
When I swipe right, on my Ionic I have lots of options, but screen wake is not one of them. Help. It stopped working yesterday. Only one month old!
Yeeeeeeeees! Thanks
Hold the left button for a few seconds. Wake option is there. Set it to auto.
Moderator edit: merged reply
Best Answer10-13-2018 15:45
10-13-2018 15:45
Hello @PaullutiquechVT, thank you for your reply, could you please confirm if you were able to find the Screen Wake option by pressing and holding the left button for a few seconds?
10-14-2018 03:51
10-14-2018 03:51
10:59
17:54
DavideFitbit
10-14-2018
10:59
17:54
DavideFitbit
yes this worked
Moderator edit: removed personal info
Best Answer10-14-2018 11:10
10-14-2018 11:10
Best Answer10-16-2018 18:00
10-16-2018 18:00
Awesome, thank you for the update @PaullutiquechVT and @pauleleazer, it's great to know that it worked for you. ![]()
Best Answer11-07-2018 17:35
11-07-2018 17:35
The swipe instruction was really confusing. Thank you.
Best Answer11-08-2018 13:14
11-08-2018 13:14
Thank you for your reply and comments @jrsmith888, and welcome to the Community forums.
Could you please confirm if you where you able to find the Screen Wake option in your Fitbit Ionic?
Best Answer11-08-2018 13:17
11-08-2018 13:17
11-08-2018 13:21
11-08-2018 13:21
