06-29-2019 09:35 - last edited on 09-01-2021 18:52 by LiliyaFitbit
Just recently my Ionic showed the fitbit logo, at first I thought it was rebooting but when I looked at it later that day it kept rebooting and going back to the logo.
I tried to restart the watch and tried to hold down all three buttons, which it would just start going into a loop, show the logo the go black and then show the logo again.
Next I plugged it in and tried to hold down the three buttons again and it did reboot correctly but once I took it off the charger it started to reboot again. I tried this again and it would never boot up again.
This is getting a little frustrating since this watch is not that old, we have two of them and the other one works just fine. Any suggestions would be much appreciated.
Best Answer06-30-2019 11:50
06-30-2019 11:50
Hello @A.A.Ron thanks for bringing your concern to my attention, it's a pleasure to assist you today/ I'd like to begin giving you a warm welcome to our Community Forums!
Seems odd that your Fitbit Ionic keeps rebooting, certainly this is not a common situation nor the way we designed our device to perform, thanks for your effort and patience troubleshooting it prior posting, I understand how frustrating this matter can be. Since the restart process was already done with no avail, I suggest you to try our factory reset procedure following the next steps:
Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
I'll be here if you need further assistance. Keep me posted.
08-15-2019 12:17
08-15-2019 12:17
I have this exact same behavior, but the Fitbit.com/setup never comes up, seems like it is truly in a restart loop. This happened after I attempted to re-pair the device after Fitbit support couldn't figure out how to resolve my issue.
Best Answer08-21-2019 15:58
08-21-2019 15:58
Hi @nrawie it's nice to see you again participating here in the Community Forums, sorry for the delay in responding your post.
I appreciate the details that were shared in your post, sorry for the inconvenience you went through with your device, thanks for taking into consideration the steps that were posted above. Let me share with you that our Support team was contacted on your behalf to receive further assistance directly with them, therefore, please keep an eye to your email inbox because they'll be in touch with you soon.
In the meantime they contact you, let me know if you have any additional questions.
Best Answer08-28-2019 03:29
08-28-2019 03:29
I have had the same issues here and fitbit simply said "it is out of warranty" by 3 months. In fact, there is a big design problem with this device, which fitbit will never ever acknowledge. So, since the support team is useless, just put your ionic in a trash and move to another serious brand. By doing so, you will save some of your time.
Best Answer08-28-2019 04:33
08-28-2019 04:33
Best Answer08-28-2019 07:19
08-28-2019 07:19
I'm on my 6th ionic due to this issue. far as i can tell it seems the wireless radio chip goes bad after a few months of use and then the whole watch freaks out. i'm well outside warranty and they're still sending me replacement ones whenever one dies.
08-28-2019 09:14
08-28-2019 09:14
I had the same issue and did a factory reset. It's been 5 days and my Ionic has not rebooted once.
Best Answer08-28-2019 14:34
08-28-2019 14:34
I have just tried this factory reset as described and now my ionic displays a red cross with the message data not deleted sync and try again. But it won't syncs or reset
Best Answer08-28-2019 15:24
08-28-2019 15:24
12-23-2019 23:32
12-23-2019 23:32
I have this same issue where it doesn’t reset from a factory setting at all and just keeps going in a reboot loop with the Fitbit logo on and then going black on the screen . What am I to do
Best Answer12-24-2019 00:48
12-24-2019 00:48
Ya its a bummer. I got my Fitbit Ionic as a early Christmas last month and it has this issue. I got in contact with fitbit and im expecting a replacement some time. I hope to never experience this again or its going to suck. I hope fitbit comes out with a better solution on there watchs like have a secondary connector to put the watch into a computer or mac and have a recovery program or something if they tend to be in the watch business.
Best Answer09-01-2021 05:32
09-01-2021 05:32
I followed all of the above steps. During the setup process on my Android device I was unable to setup the WiFi connection, receiving the error message, "An error occured while trying to obtain the list of configured networks." The error appears in a black bar at the bottom of an otherwise white screen, save for the swirling green circle in the center. It stays visible on the screen for a few moments with a green "Retry" button to the right but even tapping the button produces the no effect. The message bar will disappear but just pops back up a few moments later.
Best Answer09-01-2021 05:36
09-01-2021 05:36
09-01-2021 16:59
09-01-2021 16:59
Welcome to the Fitbit Community, @Beattyj. Thank you for your reply, @nrawie.
@Beattyj Thank you for joining the thread and sharing that you're experiencing the same issue with your watch. I appreciate your efforts and the additional details and recommend following our complete troubleshooting tips in this help article: Why can't I set up my Fitbit device?
@nrawie Thank you for the update, I understand how you are feeling. I am sure our Support team tried their best to help you, each case is reviewed individually and a solution that's being provided is based on the Fitbit Warranty. I appreciate your understanding and hope you could give Fitbit another opportunity in the future.
Hope this helps.
Best Answer09-01-2021 17:04
09-01-2021 17:04
09-02-2021 16:19
09-02-2021 16:19
Thank you for your feedback, @nrawie.
I respect your decision and wish you the best of luck with your health and wellness goals.
Have a good day.
