05-01-2018
06:26
06:52
05-01-2018
06:26
06:52
Hi
ive had my Ionic since September 2017 and it’s been amazing. However, in the last 4 days I’ve needed to charge it every 24hrs and on one day it didn’t last 20hrs. Normally it lasts 3 days! I’ve not made any changes or added any apps, the last update I had via iOS was 18April and my activity levels are no different to normal.
I’ve trying running the battery right down and recharging, I’ve done a few hard resets (holding left and bottom right buttons down for 15secs) and still have he same problem.
I’ve also noticed that it took hours to sync my active minutes yesterday and it hasn’t given me a sleep analysis this morning.
Feels like it’s failing! Help please!
Thanks!
05-03-2018 06:57 - edited 05-20-2025 05:45
Welcome to the Fitbit Community @JenR7128! Thanks for already troubleshooting this inconvenience, nice way to go!
As per the description, it seems that it has insufficient power source. Where do you charge your tracker? Have you checked if by any chance the USB port or outlet is faulty? If you haven't done so, try a different port. A UL-certified wall charger will also work. Don't use a USB hub.
Also, make sure the pins on the charging cable lock securely with the port. The connection is secure when the watch vibrates and the battery icon or percentage appears on the screen.
If after following those tips and recommendations you keep having difficulty when charging your tracker, try restarting your Fitbit Ionic once again by following these steps.
Keep in mind that the length of time your Fitbit device operates on a full charge depends on how frequently you use it and various settings.
Consider these tips when you want to conserve battery life:
In regards to the syncing issue, I'd recommend checking this article and follow the tips and recommendations.
Give this a go and let me know the outcome!
05-08-2018 22:23
05-08-2018 22:23
I’ve got the same problem. Before update it was going four days on a charge. Now it doesn’t even make 9 hrs.
I have ave changed no settings yet but would be tremendously disappointed if the latest update now requires turning everything off to regain the battery life. Very poor quality control. Is there a method to roll back the update.
Troy
05-08-2018 23:18
05-08-2018 23:18
I contacted Fitbit and they sent a replacement in the end.
Unfortunately, I now how issues with the calibration due to the latest update so will see how it goes. Battery life now much better though. Jen
05-12-2018 00:11
05-12-2018 00:11
Ok after the third recharge it seems to be back to lasting four days or so as before. The only thing I can attribute the problem to was the last update. I did get a red cross mark on the ionic at the end of the update but it seemed to be working ok although the communication between ionic and smart phone was flaky and the charge lasting less than a day. Now however it is holding the charge and the link between the ionic and smart phone is back to being excellent. So I have no idea what the problem was or why it sorted itself out.
