09-04-2020
21:55
13:05
SilviaFitbit
09-04-2020
21:55
13:05
SilviaFitbit
The screen of my Fitbit ICONIC went blank a few days after downloading the latest firmware (using iOS). Tired switching it off and on a few times but remained blank
13:37
16:22
09-05-2020
13:37
16:22
@Woopf A warm welcome to the Fitbit Community. Thanks for getting in touch about this.
I appreciate that you tried turning it off and on. I would like you to try a restart and check the display behavior after this.
Looking forward to hearing back from you!
Best Answer09-06-2020 00:35
09-06-2020 00:35
Best Answer09-06-2020 01:26
09-06-2020 01:26
13:10
16:22
09-09-2020
13:10
16:22
@AF_1 A warm welcome to the Fitbit Community. Thanks for getting in touch about this.
@Woopf Thank you for getting back.
I appreciate the troubleshooting tried prior to posting. I've shared your post with our Support team and someone will contact you as soon as possible. Keep in mind that due to recent events affecting our operations we may take a bit longer to get back to you.
I'll be around if you have any additional questions.
Best Answer09-10-2020 17:53
09-10-2020 17:53
Thank you for the support. Nicole advised me to change the clock face via the app and I tried that. There was a vibration, yet no sign of it appearing on the screen. It is still a hazy light grey emptiness. Tried all the other ways you have mentioned, back and bottom button together, etc, etc. But still nothing happened. The watch is still recording my activities though, sync ok....I cannot do the shutdown as I cannot access the settings on the clock face.
Pse advise. Thanks again
Best Answer09-10-2020 18:48
09-10-2020 18:48
What ever you do, do not complete a factory reset on your device. I did and then quickly got a " Here is a 35% coupon to buy a new fitbit."
17:34
16:22
09-11-2020
17:34
16:22
I appreciate that you tried changing the clock face and you only received a vibration. Since our team has access to your case please continue the communication through email, they'll be happy to assist.
@MclovinDaPuncak Thanks for your input.
Best Answer09-11-2020 19:16
09-11-2020 19:16
I have all the same indications, sometimes grayish screen, sometimes looks like it is trying to restart, but nothing on the screen. Please let me know if someone comes up with a fix!
12:44
06:37
09-12-2020
12:44
06:37
@Jeharr23 A warm welcome to the Fitbit Community. Thanks for getting in touch about this.
I appreciate the details mentioned. In this case, I would like you to restart your Ionic and try changing the clock face installed. After this please let me know the result.
Looking forward to hearing back from you.
Best Answer09-13-2020 15:12
09-13-2020 15:12
Me too, I have had the same problem.
Best Answer09-13-2020 22:00
09-13-2020 22:00
Best Answer09-13-2020 23:52 - edited 09-13-2020 23:56
The battery draining likely gave it an electronic/logic reset.
Good outcome, but shouldn't have to leave it to chance to bring it back to life!
Try not to let the battery drain down to near zero. Seems these batteries don't recover well from a full discharge. Although well designed electronics should shutdown before the battery fully depletes.
00:32
15:25
SilviaFitbit
09-14-2020
00:32
15:25
SilviaFitbit
Yeah this watch is a very buggy device and the worse electronic one we have ever owned. Because of all the forum reported bricked devices after trying various updates - we have finally decided to no longer risk ever updating again. We will stay firmly on 70.7.14.
For those that have bricked devices contact customer support and request they send you a replacement. For those that are offered a 25% discount on another device - get something else like a Apple or Garmin or whatever.
Moderator Edit: Word choice
Best Answer09-24-2020 02:20
09-24-2020 02:20
I was so so Glad when Fitbit decided to replace my supposedly faulty Iconic and it did arrive on 21 Sept. Setting it up was a Breeze but after 3 days, it just died. The charge on the screen showed red 0% though I have charged it and on app screen showed that it was fully charged.
AFTER that, no matter how, it refused to be charged again.
‘It is really disappointing. What can I do now?
Best Answer09-24-2020 02:23
09-24-2020 02:23
The new watch they sent me lasted 2 days.....it is 0% charge and cannot be charged again
Best Answer09-24-2020 02:24
09-24-2020 02:24
The app shows a healthy battery charge, 83%. However, the watch shows 0%
Best Answer09-24-2020 07:06
09-24-2020 07:06
Hi this is also happening to me, just started happening two days ago, I left it charging overnight, have tried the reset, the hard reset and tried changing the clock face. Still blank screen but feeling vibrations and still syncing with my devices but I cannot see anything.
Best Answer09-24-2020 07:15
09-24-2020 07:15
Best Answer09-24-2020 11:58
09-24-2020 11:58
Affects me too
