02-07-2018
03:27
11:54
SilviaFitbit
02-07-2018
03:27
11:54
SilviaFitbit
The firmware update is appearing to be held up due to lack of bluetooth connectivity. Not working over wi-fi.
Using IOS - Apple phone only got my fitbit today. Not able to use it until it has updated completely. Unsure if there is some kind of issue with the watch? Is this an issue for all Apple users
03-24-2018 20:58
03-24-2018 20:58
Best Answer03-24-2018 21:13
03-24-2018 21:13
03-25-2018 02:08
03-25-2018 02:08
I finally managed to update over WiFi and you're right the update is not great! I don't get any notifications through from my phone anymore
03-25-2018 18:18 - last edited on 06-25-2020 20:52 by LiliyaFitbit
Thank you.
Sent from my iPad
Best Answer03-26-2018 09:30 - edited 03-26-2018 09:32
I'm back to no sync. This is ridiculous! You would think fitbit would make the fixes BEFORE pushing the next new device! I'm at the point where I may just not use fitbit at all. My trainer has been trying to get me to use Garmin and he never has sync issues, not in 2 yrs! But they are ugly and I'm shallow like that 🙂
Best Answer03-26-2018 10:24 - last edited on 06-25-2020 20:50 by LiliyaFitbit
Great. Thanks for info. I will wait till they get the bugs out because I don’t have the time or enough Ionic smarts to put up with it! For some reason, I expect updates to work, the first time...
Sent from my iPad
Best Answer03-26-2018 10:30 - last edited on 06-25-2020 20:49 by LiliyaFitbit
I didn’t finish loading the update and will wait till they fix the bugs, thanks to you and a few other users who posted their experiences. Thank you so much!
Sent from my iPad
04-13-2018 05:03
04-13-2018 05:03
I have exactly the same problem. I can´t use the computer either. There it says that ionic only works with phone ?!
04-18-2018 04:53
04-18-2018 04:53
This is issue causing my phone battery to deplete and always alerting me to do the update, when they system is not letting me
04-19-2018 19:45
04-19-2018 19:45
I've been unable to update and sync with the wifi or the bluetooth for a week now, even after having restarted the phone and the watch.
What goes on???
Best Answer04-23-2018 04:09
04-23-2018 04:09
Fitbit ionic sucks! Waste of money
04-23-2018 04:24
04-23-2018 04:24
Yes!!!! Sucks sucks sucks sucks!!! I hate it and all because the stupid update
04-26-2018 21:10
04-26-2018 21:10
Won’t connect via wi-fi, Bluetooth update starts and then update starts and into process then stalls. I’ve let it runs dozens of times without luck. Tried all the hacks: restarted phone, ionic, reloaded software update; tried it using iPhone, iPad and MacBook. Nothing works. Sigh.
ill wait for another updated in hopes that will work. Or go ahead Ana switch to iWatch. That works like a charm for my wife... who continues to mock me for my loyalty to Fitbit...
05-01-2018 14:01
05-01-2018 14:01
Have tried everything mentioned here. It is very annoying. Why release an update that obviously has not been tested properly.
Wishing I had my Blaze back
Best Answer05-03-2018 05:39
05-03-2018 05:39
Unfortunately I am having this same issue. I’ve hat my Fitbit for about a ear now and it is not updating over Bluetooth. I have been trying for over a week now over WiFi and bluetooth and still no luck!!!
Best Answer05-03-2018 05:41
05-03-2018 05:41
Now I have to buy a computer just to update my ionic????
Best Answer05-11-2018 12:09
05-11-2018 12:09
My phone battery is a mess too. Thanks for pointing this out. I didn't put it together. I'm on another post about the syncing issue and some have gotten replacement devices that work. Of course no one from fitbit has jumped in with solution. Everyone has had no success with updates. In fact several had working fitbit that then stopped completely!
Best Answer05-11-2018 12:11
05-11-2018 12:11
Everyone laughs at me for the fitbit loyalty as well. Guess they must be right. Too bad fitbit won't step up and fix it or offer exchange to those of us posting on their public forum!!! Maybe posting social media would get their attention
05-11-2018 12:45 - last edited on 06-25-2020 20:48 by LiliyaFitbit
Someone from Fitbit reached out to me.
I had to do a factory reset of my Fitbit and then do the update. I had tried 7 times. This finally worked
05-11-2018 12:55 - last edited on 06-25-2020 20:49 by LiliyaFitbit
After a lot of frustration (hours with the little dial spinning and the iPhone saying “connecting” when it was really going aimlessly around in circles) and reading a number of posted solutions, I started over as follows and it worked with my iPhone 7.
1. Charge up both devices to 100 percent and keep them plugged into the charger.
2. Close the Fitbit App.
3. Disconnect the Ionic from the Bluetooth list.
4. Turn Bluetooth off. Wait a few seconds, then turn it on.
5. It should detect the Ionic and synch with it.
6. Now download the update to the iPhone. If it works, the update will walk you thru the update, but it does take 15-20 minutes to complete with a few entries from you. Once done, remove the devices from the charger and you should be fine.
I suspect some of the issues stem from the quality of the Wi-Fi connection. But a lack of written instructions from Fitbit IS NOT AN INDICATION OF GOOD CUSTOMER SERVICE.
Good luck. If this doesn’t work, search the net for the Ionic and your specific cellphone model.
Sent from my iPad
