02-07-2018
03:27
11:54
SilviaFitbit
02-07-2018
03:27
11:54
SilviaFitbit
The firmware update is appearing to be held up due to lack of bluetooth connectivity. Not working over wi-fi.
Using IOS - Apple phone only got my fitbit today. Not able to use it until it has updated completely. Unsure if there is some kind of issue with the watch? Is this an issue for all Apple users
05-11-2018 13:06
05-11-2018 13:06
Best Answer05-11-2018 13:44
05-11-2018 13:44
I have tried every one of these troubleshooting suggestions multiple times and still no luck in updating software. Will start process just fine and then about ten minutes in just hangs and nothing happens -- for hours -- just stops loading, freezes. Then have to restart ionic... was hopeful 2.1 firmware was going to fix the problem --- no dice. Frustrated.
Best Answer05-11-2018 13:54
05-11-2018 13:54
Best Answer05-11-2018 16:19
05-11-2018 16:19
Fitbit REALLY SORT THIS OUT. Yes SHOUTING!!! Blueetooth error! Wifi error. For years I have used your devices but updating the ionic on iPhones is s pain. DO YOU TEST THE SOFTWARE UPDATES ON IPHONES. Don’t say do a desktop update. You either support iphone updates or you don’t. I have wasted time away from home trying to update firmware. Powered down ionic on numerous occasions, bluetooth doesn’t work, yet updates stats!!!!!! Your premium product just is not supported correctly. SORT IT OUT!!!
05-29-2018 11:33
05-29-2018 11:33
Can't get my Ionic to update either. I've tried everything mentioned. Won't load the update.
Samsung Galaxy Note8.
Best Answer06-04-2018 04:38
06-04-2018 04:38
I have an Android phone and am getting same error message. Wouldn't allow me.to update firmware. Very frustring and annoying
06-04-2018 05:09
06-04-2018 05:09
I have done everything, torn the forums apart, and still cant get my IONIC to work. Samsung S7 Edge. I wish I could get some sort of exchange. The product used to work and doesn't anymore. Very frustrating and fitbit has certainly lost me as a customer unless this can be fixed.
Best Answer06-04-2018 05:47
06-04-2018 05:47
06:10
09:40
SilviaFitbit
06-04-2018
06:10
09:40
SilviaFitbit
6 months of torture. Fitbit is going back to Target. No more Fitbit products for me.
Moderator edit: Removed personal information
Best Answer06-09-2018 00:01
06-09-2018 00:01
Have not been able to update or sync mine now for a number of days. I’m an Apple user and Fitbit going back to store as it does not work
06-10-2018 13:03
06-10-2018 13:03
I use Android and I had trouble updating as well it's still not a hundred percent accurate period return while you can
06-10-2018 13:21
06-10-2018 13:21
06-20-2018 03:39
06-20-2018 03:39
Hi I have bought this device only 3 days back from INDIA and not able to sink the same with my OP2 (bluetooth 6.01)
It always show the error that you have put wrong code and update of firmware require to OS 2.01. If I click update the same shows that try will bluetooth or try with WIFI.
No resolution I had shown the same to 2 (two) FITBIT technicians but got no resolution. I had also tried pairing the same with MOTO G5 plus but did not worked for me.
Best Answer06-22-2018 04:21
06-22-2018 04:21
I gave note 8 and I can't get my Fitbit Ionic to update. So I am not able to use. I hope this is fitted soon.
Best Answer07-09-2018 11:22
07-09-2018 11:22
Sorry but I can’t update my fitbit ionic to ios2.1 even after having tried all your suggestions. This is the first time it happens. My using IPhone.
Best Answer07-15-2018 12:50
07-15-2018 12:50
Fitbit - people first logged this complaint on 2/7/18 - it is now late on 15/7/18 - I am unable to sync as I cannot update my icon (not through iPhone or Mac). You've replied twice and there are so many messages. What is going on? What is the fix? Where is your customer service?
Best Answer07-15-2018 13:45
07-15-2018 13:45
Best Answer07-22-2018 13:24
07-22-2018 13:24
Piece of crap. I am not being able to update ionic firmware for last 3 months. I gave up on it and unfortunately can not return the product either. so $300 scrap. Will never buy another fit bit product or recommend anybody to buy it.
Best Answer07-22-2018 13:40
07-22-2018 13:40
Best Answer07-22-2018 13:54 - last edited on 06-25-2020 20:48 by LiliyaFitbit
I had to reset to factory settings. It has updated normally since then
