02-07-2018
03:27
11:54
SilviaFitbit
02-07-2018
03:27
11:54
SilviaFitbit
The firmware update is appearing to be held up due to lack of bluetooth connectivity. Not working over wi-fi.
Using IOS - Apple phone only got my fitbit today. Not able to use it until it has updated completely. Unsure if there is some kind of issue with the watch? Is this an issue for all Apple users
07-18-2019 02:30
07-18-2019 02:30
Sam experience nothing works it's stuck in permanent needs update and trying to update over WiFi or BT always fails (10 out of 10 times)
Best Answer07-18-2019 05:48
07-18-2019 05:48
Best Answer07-18-2019 12:40
07-18-2019 12:40
Best Answer12-12-2019 05:07
12-12-2019 05:07
I’ve tried every suggestion and left it at “downloading” over night. Still cannot set up my new Ionic. What is a true fix? Can this be plugged into a PC?
Best Answer12-12-2019 08:45
12-12-2019 08:45
Lucky you....
Best Answer12-12-2019 10:04
12-12-2019 10:04
I’ve tried Fitbit Connect on my Mac. I get an alert that says Ionic and Versa can only be updated on mobile devices.
Best Answer12-12-2019 10:14
12-12-2019 10:14
Never updated for me
Best Answer12-12-2019 10:48
12-12-2019 10:48
I tried everything they said and talked to them multiple times. No fix or satisfaction. My son got an apple watch and gave me his versa. When i get a new one it will not be a Fitbit
12-20-2019 21:09
12-20-2019 21:09
Not just Apple Phones! Why can't FitBit get the updates right!! I'm on the 2nd WATCH which was kindly replaced after their update a YEAR or so ago bricked my watch. Now the new watch not even a YEAR old is just constantly playing up not finding device!! Love the idea of Ionic and even look isn't to bad, but am so over bugginess of app and watch after updates!!! Might put the WHOLE story down if I'm even bothered to!!!
Best Answer12-20-2019 21:13
12-20-2019 21:13
I wish you'd get your updates right! Looks LIKE you've JUST about bricked my second REPLACEMENT FitBit Ionic!!!
12-20-2019 21:15
12-20-2019 21:15
YES!!! It us not just an iPhone issue over these bugs when updates come along!!! Steering away from FitBit!!!
Best Answer12-21-2019 22:31
12-21-2019 22:31
For most of the life of my Ionic, I've had nothing but connection issues (ie- not being able to update). However, recently I have been leaving the Bluetooth connection on my phone ON all the time and that seems to have fixed my issues. Not everyone wants to leave BT on constantly, but if you want to update, it's something you might want to try until it does let itself be updated.
Best Answer12-22-2019 04:12
12-22-2019 04:12
Hi it has updated to 27.70.7.14!
Since the update it constantly comes up with "No Device Found!" I turn the IONIC off in settings then it takes ages and pressing either two or all three buttons for it to not even turn on at all!? Then I'll find it on and working it seems to have synched and then the time slowly loses correct time!
This happened just a little under a YEAR ago with my FIRST Ionic watch due to another FIRMWARE UPDATE.
That watch was replaced with this one worked ok until this latest update! The rigmarole I had to go through with just to get it working to find out somehow the update had frazzled the watch!!!
As it just would not keep in synch!!
It is frustrating and as it is CLOSE to specials! I will have to go away from FitBit sadly; enjoyed it!
Seems Google wants subscription fees so maybe getting rid of older devices, killer code???
Anyway thanks for advice if I get it working AGAIN? I may take your advice on the Bluetooth and keep it on...
Best Answer12-22-2019 10:07
12-22-2019 10:07
Best Answer12-22-2019 10:18
12-22-2019 10:18
Best Answer12-22-2019 19:01
12-22-2019 19:01
Thanks i did have bluetooth on all the time and it never updated. 😞
Best Answer12-22-2019 21:43
12-22-2019 21:43
Best Answer12-22-2019 21:44
12-22-2019 21:44
Best Answer12-22-2019 21:49
12-22-2019 21:49
Watch isnt the problem, phones aren't the problem, the 12/5 firmware is the problem I have all these recent symptoms and now it cant keep track of time, its 90mins behind!
Best Answer12-23-2019 07:51
12-23-2019 07:51
