07-20-2021 15:09 - last edited on 07-21-2021 11:56 by LiliyaFitbit
Hi,
I had an update on thursday (UK) on my Ionic and set it away all seemed to be ok until I went to check notifications (swiping down) as it didnt respond (notifications were coming through as could read them as they pinged). I went to try and check settings for any changes but could not scroll through the menu, it seemed that the screen wasnt responding properly to input of my finger.
I thought it was the screen protector that I had on it and water had got inbetween that and the screen, so when I had time I took the protector off but problem still presisted.
I also tried changing clock faces a few times but nothing seemed to work.
I decided to do a Factory reset on the Ionic (remove from fitbit app and from bluetooth list, hold the three bottons until fitbit logo then remove finger from bottom right until vibrate), when it rebooted the fitbit logo was pixalated so much you could not tell it was the logo, so essentially bricked.
I cant exactly remember when I got this watch but it hasnt seemed to last very long at all and it seems to be a fitbit update that has caused this problem....
Photo of problem attached
Is there anyway to get this sorted?
Thank you for your time
Best Answer07-21-2021 11:55
07-21-2021 11:55
Welcome to the Fitbit Community, @Zoopy.
Thanks for the details and a photo shared in your post and for already trying to resolve the issue. I understand your concern and recommend getting in touch with our Support team so they can look deeper into the issue and help you with this matter. Click here to get connected with them via chat or phone.
See you around.
