09-06-2018 02:09 - last edited on 09-07-2018 07:03 by MarreFitbit
Reset my screen using left and bottom buttons as my data wasn’t showing. Screen came back on but mo change. Tried another reset and now my screen won’t come on at all. Still syncing with my iPhone but screen completely off
09-07-2018 07:07 - edited 09-07-2018 07:07
Welcome to the Fitbit Community @SaturdaySteve! Thanks for taking the time to restart your Ionic, nice way to go!
Can you please confirm if you've followed these steps to properly restart your Ionic?
While reading your post I was wondering if by any chance you stopped wearing your tracker for a while? If so, what I guess here is that probably your tracker ran out of battery. Have you tried charging it at least 1 hour? Even if you don't get anything on the screen I'd recommend charging your tracker at least 1 hour to see if the battery icon comes up after that period of time. Charging fully takes about one to two hours.
If after the 1-2 hours you don't get anything on the display, check if the contacts on your tracker or charging cable are not dirty. Dust and debris can accumulate over time and prevent a charge. Try cleaning them by following these instructions.
How do you charge your buddy? Have you checked if by any chance the USB port or outlet is faulty? If you haven't done so, try a different port. A UL-certified wall charger will also work. Don't use a USB hub.
If so, plug the charging cable into the USB port on your computer or a UL-certified USB wall charger.
Hold the other end of the charging cable near the port on the back of the watch until attaches magnetically.
Give this a shot and let us know the outcome!
02-23-2019 02:21
02-23-2019 02:21
Really frustrating that I have tried all options suggested to get my Ionic to switch on and it will not...
03-02-2019 02:09
03-02-2019 02:09
Same here bud, I've had my Fitbit for a little bit over a year and never had any big issues. Until the same thing happened to me today... It blows
03-02-2019 10:55
03-02-2019 10:55
Mine just did the same thing last night!!!! Won’t turn back on
03-02-2019 18:43
03-02-2019 18:43
At this point they're all just self-destructing or something software related because mine was working mechanically perfect before it just decided not to turn on anymore
03-03-2019 05:19
03-03-2019 05:19
03-03-2019 06:07
03-03-2019 06:07
Sad thing that Fitbit refered me to the warranty....despite it just being 45 days outside 1 year....
03-03-2019 13:41
03-03-2019 13:41
Mine did just the exact same thing today. I noticed it wasn't vibrating yesterday when I was getting text messages and noticed it wasn't syncing. I deleted it off my Fitbit app, forgot it on Bluetooth, even uninstalled and reinstalled the app. Rebooted my watch and nothing. Then I did a factory reset. It finally connected my phone. And finally said I could update it. It got halfway thru the update, the app said it couldn't complete it and to try over WiFi, same thing happened. I cancelled the update and my Ionic shut off. I assume it's dead. It was fully charged. Contact points are clean. I followed every troubleshooting steps on this site. Held all combinations of buttons down for up to 2 minutes just to be sure. Several times. It's insane that we pay 300 bucks for this and all customer support will do is tell you to send it in and replace it. Which is only ok as long as you have every scrap of original packaging. Very poor service. My Ionic is only 3 months old. This shouldn't be happening.
03-08-2019 20:42
03-08-2019 20:42
Me two after 1 year passed it automatically off and cannot turn it on again
03-09-2019 04:38
03-09-2019 04:38
Sounds all too familiar....wonder if Fitbit customer care actually takes note and does something...instead of giving the usual feedback that it is out of warranty.
Why has Fitbit not had a recall of the ionic to sort it out ?
03-13-2019 07:53
03-13-2019 07:53
Same here. Went to bed with a 89% and now will not turn on at all. Tried to reset and nothing. Just at 14 months old.... huge disappointment right now.
03-13-2019 14:32
03-13-2019 14:32
Same. Screen started acting weird. Then touchscreen stopped worked. Did a factory reset. Now it's not turning on! 250$ for 1 year and 2 months. I hope they will solve the issues. Bummed. No more Fitbit if not
03-15-2019 19:36
03-15-2019 19:36
Did it ever come back on?
03-15-2019 19:43
03-15-2019 20:08
03-15-2019 20:08
Did you or anyone else manage to fix the issue?
03-15-2019 20:11
03-15-2019 21:58
03-15-2019 21:58
03-15-2019 22:00
03-15-2019 22:00
03-16-2019 06:15
03-16-2019 06:15
Yeah I had to return mine. But it's ridiculous I have to go 2-3 weeks without my watch. Their customer service is funny to me. If it's not fixed after you try to reset it, they just tell you to send it in.
