07-31-2019
16:02
13:27
SilviaFitbit
07-31-2019
16:02
13:27
SilviaFitbit
Seen this posted multiple times. Tried all solutions still not working.
green light stays on all the time. When I wear it, when I dont, while it is charging.. even now.. its dead.. but there is little green light on.
things I have tried
attempted to re-start- never got the logo screen
let the battery run down and re-charge on multiple chargers
factory reset
Nothing has helped and it wont hold a charge for more than a few hours.
Thanks
Matt
Best Answer08-01-2019 13:26
08-01-2019 13:26
A warm welcome to the Community @R_U_Sharp_2.
Thanks for the details mentioned and the troubleshooting tried.
It's pretty weird that your display isn't working but you're seeing a little green light on. In this case, I've shared your post with our Support team and they will continue assisting you.
Best Answer08-01-2019 17:07
08-01-2019 17:07
Display works just fine.
Wont hold a charge.. green light stays on... everything else seems to work.
Really happy that this issue is posted so many times and when I contact support.. I get the " its outside the warranty period. But we will be so generous as to give you 25% off a new one." Its been 16 months since I purchased this one.
Not going to be taking advantage of that offer on a new one.
I wouldnt have an issue with it if my decice was older or there wasnt so many posts about the same issue.
Won't ever buy another Fitbit. Fitbit really stands behind their products!
08-02-2019 12:43
08-02-2019 12:43
Thanks for getting back @R_U_Sharp_2. I appreciate you've shared your experience with our Support team. Each case is reviewed individually and the option provided is based in the Fitbit Warranty.
Hope you can give Fitbit another opportunity in the future.
