06-04-2021
08:04
13:53
SilviaFitbit
06-04-2021
08:04
13:53
SilviaFitbit
Why is bedtime and wake-up time ridiculous now?
I don’t go to bed at 1pm and wake up at 10pm.
if I go to details, times are correct. What’s up with that?
Thanks
13:56
08:24
06-05-2021
13:56
08:24
@SunsetRunner Welcome to the Fitbit Community. Thanks for the details mentioned.
If you have 5 or more sleep logs, your sleep goal is estimated based on an average of these logs. Your wake-up time target is estimated based on the time you typically wake up each day, and your bedtime target defaults to the time you should go to sleep in order to meet your sleep goal.
If you have fewer than 5 sleep logs, you can provide an estimate of how much sleep you get on a typical night, and your sleep goal is set based on this estimate. You must manually set your bedtime and wake-up time targets.
To manually set bedtime or wake-up time targets, do the following:
Also, please let me know where exactly you're seeing incorrect sleep times set. If possible attach a screenshot to your next reply.
Hope this helps.
