01-26-2019 01:17
01-26-2019 01:17
HI My Ionic is having issues. It has the following issues:
1. Not measuring steps - I did a 2 km and walk and said I did 93 steps.
2. Not measuring heart rate at all. Not on the clock face or when I connect to the app. The back light for measuring heart rate isn't on at all.
3. Doesn't flick on when I flick my wrist. I have to press the left button to get it to work.
4. The battery life is really short. I charged it overnight and two hours later its used 30%.
I have done the following:
1. Reset by pressing the left and the bottom right buttons
2. Done a factory reset.
3. Checked that the heartrate measuring is on and that the auto turn on is on
Help??!!!
Best Answer01-26-2019 04:09
01-26-2019 04:09
@fecrispy sorry to hear you are experiencing problems. It sounds like you have tried the usual diagnostics to try and sort it. What I would suggest now is to contact customer support so they can take a closer look and assist you further.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
