12-28-2018 03:56 - edited 12-28-2018 03:58
I have been having all sorts of issues with my ionic the last few days. Never had any problems until I updated the firmware. It started out not syncing properly to my phone and then the clock started losing time.
Last night after a long time trying to sync to my phoneI managed to get it to sync to the computer but only while it was charging (couldn't do it with Bluetooth). This was all after multiple times of turning Bluetooth & phone on & off, reinstalling the fitbit app & restarting the tracker.
Tonight afer more drama I decided to factory reset it & now all I get it a flashing fitbit logo. Now I've got a useless watch... Might have to drag out my old blaze which I don't really want to have to do
Best Answer12-29-2018 07:53
12-29-2018 07:53
A warm welcome to the Community @Roades! Thanks for the details that you've mentioned as well for the troubleshooting performed.
It sounds like your Ionic didn't finish the firmware update and that's why it's showing the Fitbit logo. I would like you to double check that you have the latest firmware version which is 27.33.1.30.
Please try to perform a restart and then if it's still not syncing to your account, try these steps Why won't my Fitbit device sync?.
Hope this helps! Keep me posted.
01-29-2019 12:06
01-29-2019 12:06
I am having the same problem, Roades. I decided to do a factory reset of my Ionic to see if it would fix my power problem. I have to charge it two to three times a day or it dies.
Every since I did the reset, all I see is the Fitbit logo and a scrolling "Welcome" message in numerous languages with the setup address. I went to the setup page but I don't konw where to go from there.
I have to say, I'm disappointed with my Ionic overall. I like the features but I always have trouble syncing it and this power/battery problem makes it almost useless.
01-29-2019 12:24
01-29-2019 12:24
I'm having the same issue. So far I have figured out that you have to unpair it from you phone then repair it and delete it from your device. Then go through set up a new tracker to your device. Im getting stuck on my phone trying to find a wifi network, which is odd because my phone is connected to it but the app wont find it. So completely frustrated!
02-01-2019
14:19
07:12
02-01-2019
14:19
07:12
A warm welcome to the Community @WalterMitty and @tmtipton74. Thanks for the troubleshooting that you've performed as well for the details mentioned.
@WalterMitty The welcome and set up message usually appears when your Ionic isn't set up to your account. You just need to follow these set up procedure in order to properly connect your watch to your account again. Don't forget to choose the existing user method. I've shared your post with our Support team and they've mentioned that you already have a case with them, please continue the communication via email.
@tmtipton74 Thanks for mentioning what has worked for you. In this case, I would like you to restart your Ionic and then try to set it up once again.
I'll be around if you need further assistance. Hope this helps.
Best Answer03-08-2020 21:15
03-08-2020 21:15
I am having the same problem! It's March 2020! I don't know what to do. My watch has been out of commission for over a week now. This is not good fitbit. Not good. Too many ppl have this issue And there seems to be no real solution.
13:52
07:12
03-11-2020
13:52
07:12
@FredSanford Welcome to the Community. Sorry for the delayed reply.
Thanks for getting in touch about this. I see where you come from.
I would like you to try to restart your watch and check if your screen starts working again. If you keep experiencing the same, please let me know what you're seeing on your Ionic's display.
Keep me posted.
