03-03-2018 01:46
03-03-2018 01:46
My ionic was working great and then the battery died the other day. I plugged it in to charge and came back a few hours later and it still says 0% when you press a button. It has now been on charge for 3 days and still says 0%. I have tried wall chargers and running it off the laptop USB but still nothing! I can't reset or do anything as there is no battery life! Help!
04-16-2021 16:54
04-16-2021 16:54
Try a higher current charger.
04-16-2021 17:16
04-16-2021 17:16
04-16-2021 22:20
04-16-2021 22:20
04-17-2021 06:27
04-17-2021 06:27
Fitbit knows about this problem but doesn't care. Once you're out of warranty you may as well throw it away. I've tried every suggestion (new charging cable, charging stand, cleaning contacts, resetting...) and nothing worked. Do yourself a favor and get a Garmin.
04-17-2021 06:28
04-17-2021 06:28
04-17-2021 06:30
04-17-2021 06:30
Do like I did, bought a Garmin and then posted to my 1000 or so friends and followers on FB and Twitter that Fitbit knows about this defect and doesn't care. Told them to spread the word to not buy Fitbits.
04-17-2021 06:43
04-17-2021 06:43
04-17-2021 06:49
04-17-2021 06:49
04-19-2021 14:53
04-19-2021 14:53
04-20-2021 06:38
04-20-2021 06:38
04-20-2021 07:44
04-20-2021 07:44
I just one of these ionics to fix from a friend.which had similar sympton. When I first recieve I plugged it to a cigar lighter USB charger in my car ( it's a 2.4A charget) instantly showed %0 battery and that was it. Couldn't get it to display anything again. Tried unplugging and plugging back in, different button combinations but nothing would work. I left it plugged in to a power bank while in store for abou half hour. When I grab fitbit it was warm almost hot. Fairly sure battery was charging just based on the heat. But still could not get any display. Anyway when I got home I plugged it in to my desktop PC and instantly showed %73 battery and all functions worked fine. I'm %100 sure but I want to day I read somewhere that if a firmware update is interrupted you will have to plug in to a computer with internet to finish firmware update.
04-20-2021 08:40
04-20-2021 08:40
04-20-2021 17:25
04-20-2021 17:25
I tried your fix and it didn't work. I've read many posts from other Ionic victims who tried this fix and it didn't work. So much for it working 100% of the time. When a product has a known defect and the company won't stand behind their product then that company doesn't deserve customers
04-20-2021 17:50
04-20-2021 17:50
04-20-2021 21:35
04-20-2021 21:35
04-20-2021 21:47
04-20-2021 21:47
04-21-2021 10:43
04-21-2021 10:43
04-21-2021 14:19
04-21-2021 14:19
Hi mate, my Fitbit is doing the same. I had issues charging, then with persistence and finding the sweet spot by wiggling the cable it charged, it was always an issue finding the sweet spot after this. Then the backlight started to fade while it still had charge. Now it won’t charge, no matter how I wiggle or change charge points etc. I can’t reset it if The screen is blank. Any suggestions?
04-24-2021 15:40
04-24-2021 15:40
Worked with the restart. Thanks!
04-25-2021 11:04
04-25-2021 11:04
