Ionic stuck on 0% and won't charge
ANSWERED
My ionic was working great and then the battery died the other day. I plugged it in to charge and came back a few hours later and it still says 0% when you press a button. It has now been on charge for 3 days and still says 0%. I have tried wall chargers and running it off the laptop USB but still nothing! I can't reset or do anything as there is no battery life! Help!
660 REPLIES 660
Please follow my original post step-by-step.
It worked for me.
*TDC*
My iconic is stuck on 0%. I have tried all the suggestions made within the blog to no improvement.
I will call customer support.
it wont charge
Good day again.
My fitbit wouldn't charge, it would stay on 0%, but the display would show
0%, meaning there had to be some power.
I checked this forum, and read what wasn't working.
I think (not sure) but I think there is an issue with the bluetooth
connection, perhaps there is a priority to connect before charging.
I then followed the steps exactly the way I wrote out in the post above,
and other people followed it and helped them.
>From your initial reply, I see you are not following the steps.
Just to let you know, I am just a fitbit user.
*TDC*
Hello everyone! Thanks for your continuous participation on this thread regarding Ionic stuck at 0% and not charging. Also, thanks for sharing all the workarounds that had helped you to get this sorted.
If you haven't done so already, @tdcfox shared some great steps that has helped him and other users too. Please check those steps on his original post by clicking here and try them out.
Let me know how it goes! Smiley Happy
Santi | Community Moderator, Fitbit
Like my response? Vote for it! Also, accept as solution!
hello
I had the same issue and figure out what the problem is. clean the back of the fitbit around the 3 contacts with a soft brush and blow off the stuff that comes out. I used a wooden toothpick because that what I had handy. I noticed the cable plug was sticking out and wondering that wasnt making contact...and that was it.
let me know how you made it
I agree with you:  I did clean the connectors on the watch and on the charger a few times.
Only today day did I finally see a small metal shard hidden and stuck magnetically on the inside grove. With tiny tweezers I was able to pull it free of the magnetic charge.
The watch now connected to the charging cable is loading the battery like new.  Mahalo to the Fitbit Community
@cocoliso59 Welcome to the Fitbit Community! Thanks for posting the experience you have had with Ionic not charging and the workaround that helped you to get it sorted. I'm sure this will be very helpful for the Community. Glad to read you are back on track!
@SunsetRunner I hope you're doing well! A'ole pilikia my friend! I'm really glad to read that you found help and a solution on the Fitbit Community! I'm glad you are back on track now.
Also, take a look at the Discussions Board as you will find a lot of interesting things there. Feel free to post on any thread you want. If you are looking for Fitbit friends to compete with on challenges, check this thread to add some!
See you around! Smiley Happy
How can you do a factory reset of the ionic is at o% charge and won’t turn on????
You can’t
Reset to mfg setting at 0%. I tried
What do you mean you can't
Sent from my Verizon, Samsung Galaxy smartphone
Ionic stuck on 0% and won’t charge up. Have looked in the forum and followed others peoples advice. Still won’t charge.
Same here! The frustrating part is moderators will keep suggesting the same things over and over. Like how are you supposed to do a factory reset when the darn watch is dead!!? Now, they want me to take a video of me attempting their ridiculous suggestion, write a handwritten note, and send it to them. First class customer care right there.
Sent from my iPhone
This is the most stupid advice I’ve ever heard. The Ionic is st 0% which means it is not accessible at all. Do it is impossible to open the settings on it and reset
Yes! Definitely idiotic. My plan is to let the Ionic sit off the charger for a few days in hopes that it will completely discharge...and maybe just maybe it will respond when I try to charge it again. I’ve done it with other electronics before and it has worked, but I’ve also had them for years before they screwed up...not less than three months like the Ionic.
Sent from my iPhone
You can still factory reset a 0% ionic. It won't help -- the fact is these watches just have terrible batteries that die after six months and fitbit is trying to minimize liability by giving confusing instructions and finding contrived excuses to weasel out of warranties -- but you *can* factory reset a 0% ionic. Here's how: https://photos.app.goo.gl/7xo8H8UFrXTdbjfN8
Hopefully you'll have better luck getting fitbit to honor their warranty than I did 😕
I have tried every single combination and suggestion of buttons I have come across...none of them have resulted in anything.
Sent from my iPhone
I’ve tried this and all that happens is a quick flash and then 0% displays again. No logo screen. I got this Ioninis less than a month ago.
Get Outlook for iOS
Great thank you it worked.
Ok. Just let it charge for a few hours
