03-03-2018 01:46
03-03-2018 01:46
My ionic was working great and then the battery died the other day. I plugged it in to charge and came back a few hours later and it still says 0% when you press a button. It has now been on charge for 3 days and still says 0%. I have tried wall chargers and running it off the laptop USB but still nothing! I can't reset or do anything as there is no battery life! Help!
07-03-2018 05:09
07-03-2018 05:09
Mine did the same thing and now works fine
Best Answer07-03-2018 06:06
07-03-2018 06:06
11:22
07:51
07-03-2018
11:22
07:51
@SunsetRunner I hope you're doing well! Thanks for trying all of those steps. I went ahead and contacted you via PM. Please keep an eye on your Community inbox.
@Richie33 Welcome to the Fitbit family! Thanks for reporting this situation. I went ahead and created a case with customer support in your behalf. Keep an eye on your email inbox for next steps.
@jjoonathan Thanks for sharing the workaround that helped you out. I'm sure a lot of users will find that helpful to get back on track.
@Maldives20-14 @rscottohtx It's great to see you in the Fitbit forums! I'm really glad to read that you found a solution at the Fitbit Community and that it is working properly for you.
@cocoliso59 @SunsetRunner I hope you're doing well! Please try the workaround shared on this post about factory reset. It is possible to do!
Keep me posted! ![]()
07-11-2018 01:26
07-11-2018 01:26
I tried this and it didn’t work at all now the problem is worse,
its stuck on the setup screen on the ionic and it wont setup because there ain’t over 50% battery.
Best Answer07-14-2018 15:11
07-14-2018 15:11
My watch was stuck at 0% ... and would not charge. Once I rebooted my phone (while my watch was plugged into the charging cable) this seemed to cause the watch to reset and it started charging and then worked again.
So, left my watch plugged into the charging cable and simply rebooted my phone.
Best Answer07-15-2018 04:55
07-15-2018 04:55
14:48
07:51
07-16-2018
14:48
07:51
@Rob21287 Welcome to the Fitbit Community! Thanks for trying those steps in order to sort this out.
I'd recommend trying the workarounds shared on the two posts above. It has helped other users in the past so it is worth giving it a try:
@crockdaddy @tdcfox I hope you're doing well! I'm glad to read that you are back on track. Thanks for sharing the workarounds that helped you out with this.
Keep me posted!
07-23-2018 08:11
07-23-2018 08:11
Right out of the box my New Ionic would not charge. Kept getting message “Not Charging. Not Enough Power Detected from this Source." Tried charging first on my PC, then my PS4, my portable charger, and finally wall outlet. I contacted Fitbit about and they are sending me a new charger. I took upon my self to go purchase a replacement charger to test and still nothing. The device is completely dead now. I got mine through a health solution partner website of Fitbit.
16:44
07:51
07-23-2018
16:44
07:51
@TDKilgore Welcome to the Fitbit Community! Thanks for sharing the experience you have had with your new Ionic not charging.
Are you getting the message on the watch's display? Please check these solutions for batteries that are not charging, you will find this helpful.
Also, if it keeps doing the same, I'd recommend following up with the case you already have with customer support and letting them know about what happened. That way, they can keep checking on your device and provide a better solution.
Hope this helps. Keep me posted! ![]()
07-31-2018 03:40 - edited 09-03-2018 20:36
My fitbit won't charge. This is my first post here . I've had to come on here most weeks for things going wrong Anyway, my ionic now won't charge and its on 0%. I have tried different charging places. I can't reboot the fitbit either way. I've tried restarting my phone and doing a sync turning on /off Bluetooth. I've tried so many things. If I do get it working again, I'll then try and sort out just about every other thing that could go wrong with it.
Update: My fitbit won't charge at all. Ecerytime I charge it I have problems but this time no solution has worked. I have resorted to rubbing alcohol, toothbrush, toothpick, changing charge locations, connecting reconnecting literally hundreds of times over the last week. I have left it on charge for days which previously worked but not now. When it does work, the ionic has vibrated once in the past 1-2 months - it gave me a shock. I get some notifications. Watchfaces only last for up to a week before forced to change - even fitbit designed ones. Where do I stop I could go on and on.
07:04
07:51
07-31-2018
07:04
07:51
@Cokeboyne Welcome to the Fitbit family! Thanks for reporting that you are also experiencing the same situation with Ionic not charging.
Why are you not able to restart your watch? Please follow the steps on this article to restart it, don't worry if your watch isn't charging, try it out. This has helped other users in the past.
Also, check these solutions for batteries that are not charging. You should find this helpful too.
07-31-2018 07:41
07-31-2018 07:41
07-31-2018
08:54
07:50
07-31-2018
08:54
07:50
@cocoliso59 Thanks for your reply and for sharing the workaround that helped you out with this.
I'm sure this will be helpful for other users who might be experiencing the same situation.
Additionally, have you checked the Feature Suggestions Board? If you have any ideas for future features you would like to see on your Fitbit device, this is the best place for asking. Feel free to search for existing feature suggestions or add you own original one!
See you around! ![]()
07-31-2018 13:07
07-31-2018 13:07
15:46
07:50
08-01-2018
15:46
07:50
@Cokeboyne Thanks for your reply and for trying all of that.
I went ahead and created a case with customer support in your behalf. Please keep an eye on your email inbox for next steps.
Keep me posted!
08-01-2018 17:48
08-01-2018 17:48
Last night after 1.5 days of trying to get it to charge trying all sorts of things, but having left it as I'd given up on it, I found it had charged itself to almost full. I then had to sync it as time was a couple of days or which took multiple forced restarts of fitbit and phone before it would work. Still won't sync for phone calls or messages.
09:17
18:31
SantiR
08-03-2018
09:17
18:31
SantiR
I woke up today finding my Fitbit dead and needing charged. When I plugged it into the charger I noticed it wasn't lighting up or doing anything. So I waited about an hour and still nothing. Wanted to assure the charging area on the watch was clean. So I took a toothbrush scrubbed it really good got all the dirt out dried it off, plugged it back in to the charger and boom! It works! #toothbrushaction #resolvedcharge
Moderator Edit: Format
Best Answer08-04-2018 17:36
08-04-2018 17:36
If my Fitbit is only showing 0% how am I supposed to go to the settings app on the watch?
Best Answer08-06-2018 11:45
08-06-2018 11:45
I have had this watch less than a year, got it as a Christmas gift, and when the battery died I couldn’t get it to turn back on. I went to a few different troubleshooting websites and tried a few different methods of turning it back on and it just won’t. It doesn’t even light up like it’s charging. Suggestions?
Best Answer08-07-2018 17:38
08-07-2018 17:38
I am having the same problem , the battery has gone & it will not charge. For what this watch cost I am fuming
