03-03-2018 01:46
03-03-2018 01:46
My ionic was working great and then the battery died the other day. I plugged it in to charge and came back a few hours later and it still says 0% when you press a button. It has now been on charge for 3 days and still says 0%. I have tried wall chargers and running it off the laptop USB but still nothing! I can't reset or do anything as there is no battery life! Help!
09-06-2018 13:39
09-06-2018 13:39
I haven't been able to get my fitbit to charge for well over a week. Now.i have tried cleaning the contract with a toothpick, toothbrush, rubbing alcohol but nothing works. When it just went flat this time I could get the 0%for a little while but now I don't even get that. I had further problems with charging after my initial issues but it would start charging in 1-2 days after plugging it in. When it was working, it never vibrated except for once, and it was hot and miss on whether the notifications would work. I also can't seem to get my watch faces to last more than about a week before they stop working and have to change - this includes fitbit own design faces.
Best Answer09-11-2018 12:58
09-11-2018 12:58
Hi
I have tried to charge my ionic and have had no success. The screen wont even light up.
Not sure what to do?
Best Answer09-11-2018 13:17
09-11-2018 13:17
13:31
18:32
SantiR
09-14-2018
13:31
18:32
SantiR
That's a stupid fix! This Thread is because the ionic is "stuck" on zero percent and won't charge. Which means that you can't access anything within the ionic software. So either you don't work for Fitbit, or don't care about the customers, or are just reading your script from some paper that you haven't taken time to read for yourself. Just horrible reply.
Moderator Edit: Format
09-14-2018 20:14
09-14-2018 20:14
Best Answer09-15-2018 06:49
09-15-2018 06:49
If the battery is dead and the Ionic won't turn on how can I go into settings on my Ionic and do a factory reset?
Best Answer09-15-2018 08:51
09-15-2018 08:51
Best Answer09-17-2018 06:56
09-17-2018 06:56
Best Answer09-17-2018 07:00
09-17-2018 07:00
08:22
10:52
09-19-2018
08:22
10:52
Hello everyone! Thanks for your continuous participation on this thread regarding Ionic not charging and being stuck on 0%. Also, thanks for all of your efforts in reporting this and providing as much details as you can. Thanks to the ones that have tried different steps to sort this out.
If you haven't done so already, please perform a restart on your Ionic. This has helped other users in the past. You can also try doing this while it is plugged in in case it doesn't have any battery power.
You could also take a look at these solutions for batteries that stopped charging. This should also help you out.
Hope this helps. Keep me posted! ![]()
09-22-2018 11:02
09-22-2018 11:02
How can you perform a factory reset with zero power?!
Best Answer09-24-2018 07:43
09-24-2018 07:43
Hey there @ardisse, it's nice to see you here! If the tracker doesn't have any battery power, you can perform the restart while it is plugged in the charger source.
Let us know if you need further help!
10-09-2018 12:29
10-09-2018 12:29
My wife has the same thing happen, and since it was bought from NewEgg fitbit won't help us at all. She's to the point she's considering going to Apple instead. Bit frustrating after all the fitbit loyalty she has had and I have tried everything to get it to work.
Best Answer10-09-2018 12:42
10-09-2018 12:42
Best Answer10-09-2018 12:57
10-09-2018 12:57
Best Answer10-09-2018 14:25
10-09-2018 14:25
Hello
my fitbit is doing the same and I can’t doe any kind of resert to it
please help
Best Answer10-09-2018 16:39
10-09-2018 16:39
Best Answer10-11-2018 03:19
10-11-2018 03:19
It did not work.
10:03
18:01
EdsonFitbit
10-11-2018
10:03
18:01
EdsonFitbit
Sorry it did not work. It fixed mine. It had so much gunk in that little ditch it would not connect to the charger. If this did not fix it contact customer service and maybe they can help.
Best Answer10-12-2018 06:01
10-12-2018 06:01
Sorry to hear that your wife's tracker is still having difficulties when you guys try to charge it @osubucksfan9. Have you tried some of the recommendations you received in this thread? Did you clean the tracker and the watch contacts? For instructions, see: How do I clean my Fitbit device?
While reading your post I was wondering if you've contacted our support team? You mentioned here that Fitbit won't help you at all, so I assumed you've contacted our customer support team, but I couldn't find any records on my end. Did you use your wife's email to contact them?
Thanks you'll for your tips and recommendations @ardisse, @SunsetRunner, @Maen_AlJammal, and @Jeeper53!
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
