05-05-2021 06:50 - last edited on 05-06-2021 11:58 by LiliyaFitbit
Hi. My Ionic froze so I done a full factory reset, as per Fitbit instructions, and I now have the reboot screen with the different languages scrolling underneath. I try to sync the app to the watch via my phone and PC, and it appears the bluetooth is not on on the watch to do so. I am in limbo as the watch will not do anything further than the reboot screen.
Best Answer05-06-2021 13:00 - edited 05-06-2021 13:01
Welcome to the Fitbit Community, @Gnarlyscoots.
Thanks for the details shared in your post and for already trying to resolve the issue. I recommend using your phone and trying the following:
1. Connect the watch to the charging cable.
2. Restart your watch. For instructions, see How do I restart my Fitbit device?
3. Make sure your Fitbit app is updated to the latest version: How do I update the Fitbit app?
4. Restart your phone.
5. Remove your watch from the list of Bluetooth devices paired to your phone. On your phone, go to Settings > Bluetooth > find the watch in the list > find an option to forget the device.
6. Open the Fitbit app, tap the Today tab, and tap your profile picture.
7. Tap Set Up a Device and follow the on-screen instructions to reconnect your watch to your Fitbit account.
Hope this helps!
Best Answer05-12-2021 14:34
05-12-2021 14:34
Hi.
Thank you for this. I had unpaired the ionic previously and was getting no luck, so following your guide to a T, I had two failed attempts and was about to just bin it, to be honest. I tried again this evening, 12/05/21 @ 2100hrs and this time we appear to have some luck..
Lets hope it lasts. Thank you again.
