10-16-2019 21:33
10-16-2019 21:33
After about 14 months my Ionic screen displays 0. I have tied everything posted on this site. As nothing was working I did the hard reset{big mistake} now I get the red x data not cleared.Removed icon and removed device and started new set up. Loads to 12% and starts searching for iconic not found. I have obstructive sleep apena {can't breathe} and depend on my sleep tracker to make adjustments to my mask the next day. My health depends on this Ionic sleep tracker and need it working. Weird many of us had the problem the same time. Phone is samsung S9+
11-17-2021 15:59
11-17-2021 15:59
Hello My Fitbit ionic watch worked perfect there were no issues. And then I did an update after the update there was a red X and I have not been able to use it cents. I have tried multiple times to do the reset I have worked with the support team and nothing seems to have worked. All I want is to undo the update and continue using my ionic watch which again did not have any issues prior to the update. Please help!
12-28-2021 03:47
12-28-2021 03:47
Hi have you tried removing the ionic completely and and reinstalling from new? Have had the same problem, deleted from account and reinstalled as if it was new it worked lost data that I hadn’t synced but it is a pain as takes 30-45 mins.
good luck
12-28-2021 04:30
12-28-2021 04:30
