02-01-2019
06:23
06:36
SantiR
02-01-2019
06:23
06:36
SantiR
Again today my Fitbit failed to record lengths whilst swimming. I had done 28 Fitbit said 13, finished the 80 and Fitbit said 45 lengths. This happens every third or fourth swim at the moment. Other times it is accurate. Anything obvious causing this?
Also, today app changed, and I am no longer post swim to edit the distance which I have been able to do until today. Not sure why this has been turned off? Although to be fair it doesn’t recalculate anything (most importantly calories, active minutes which I am trying to track week to week improvements).
Looked at a couple of other posts today and the screen shots of swimming app seem variable, mine used to show a breakdown per 100m, but this disappeared sometime ago, but others still seeing it. Any ideas to what’s changed?
Moderator Edit: Updated Subject for Clarity
Best Answer02-03-2019 06:35 - edited 02-12-2019 11:53
@LarryRed Welcome to the Fitbit forums! Thanks for taking the time to report the situation you are experiencing while tracking swimming with Ionic. Thanks for sharing all of those details regarding this.
It is strange that it is only happening some times. In this case, I'd recommend performing a restart in your Ionic. This should refresh it and swimming should be tracked correctly.
How are you tracking your swimming sessions? Try to always use the swimming option on the Exercise app on your Ionic. Make sure you are following the edit exercise steps shown on this article.
You could also try logging out from the Fitbit app, rebooting your phone, and logging back in to check if that helps.
Keep me posted! ![]()
Best Answer02-08-2019 03:23
02-08-2019 03:23
Hi Santi, thanks for the response. I was hoping to go swimming before replying but been laid low with a cold.
I always use the swimming option, it probably works correctly 75/80% of the time (my wife's has a similar issue on a similar frequency). Will try the reboot, but I regularly reboot the iconic - to keep it syncing. So not sure this will help as this has been off and on for a few months now. Will advise if it keeps happening.
On editing the exercise - followed instructions and can now edit swim distance again. So thanks! (Just a shame it doesn't recalculate calories - my tracking obsession).
Laurence
Best Answer03-04-2019 17:41
03-04-2019 17:41
My Iconic has been doing the same thing while swimming. It seems to have started after the latest update a month or so ago. It was very reliable up until then. Now I cannot trust it. Sometimes good until a certain number of laps, then may shut down or just stop counting.
Best Answer05-18-2019 23:21 - edited 05-18-2019 23:35
Best Answer05-19-2019 00:51
05-19-2019 00:51
