03-20-2018 07:35
03-20-2018 07:35
I saw there was a new update on the fit bit app for my ionic. Every time I try to update it though, it starts updating very slowly, shows it is around half way installed and then just sit in the same spot, not making anymore progress. I have tried turning my phone off and on again, turning the Bluetooth off and on again, restarting my fit bit device, reconnecting to the internet, nothing is working. It is stuck in the installing process.
03-21-2018 08:54
03-21-2018 08:54
I reset the ionic to factory settings and unpair it from everything, restarted the ionic and add it to the fitbit app all over again connected to the wifi and FINALLY worked I took like 5 hours ! But its working fine now 🙂 !
Best Answer03-20-2018 10:18
03-20-2018 10:18
same thing here with my ionic im trying since yesterday all day and today . No results.
Best Answer03-20-2018 10:24
03-20-2018 10:24
Both of you, do a RESTART and try again. Keep in mind that it's much better all around to use wifi for your updates if possible rather than bluetooth.
Best Answer03-20-2018 10:27
03-20-2018 10:27
Best Answer03-21-2018 08:45
03-21-2018 08:45
I have restarted my internet, Bluetooth, the fitbit, the app, my phone, and my computer at least 8-9 times. It does not connect to the internet unless I am connected to Bluetooth and does not give me the option to update over wifi. I have tried to connect JUST to wifi, it will not let me. I have also tried to "forget" my ionic from Bluetooth and the app and re download it, yet it does not update for me.
Best Answer03-21-2018 08:54
03-21-2018 08:54
Best Answer03-21-2018 14:54
03-21-2018 14:54
Thank You! I went through these same steps and mine updated and now works as well! Thank You for your solution... I almost went crazy. Lol
03-21-2018 14:57
03-21-2018 14:57
Great
! You welcome !
Best Answer07-04-2018 10:33
07-04-2018 10:33
My watch will not restart or even turn on. But the green light in the back is flashing for a charge.
Someone please help.
