11-07-2017 17:50
11-07-2017 17:50
So I was able to setup my ionic and pair it to my phone. I then connected the ionic to my Samsung laptop and was successful in migrating music. My ionic sync with my laptop but now it no longer pairs to my phone. Bluetooth doesn’t recognize the device. Question is how to fix so both Bluetooth and WiFi connections work?
Best Answer11-07-2017 18:33
11-07-2017 18:33
Try after stopping blutooth on laptop or shut it down.
11-08-2017 05:43
11-08-2017 05:43
Thanks, that works. However this morning the weather app is not syncing... everything else works. Ugh!
Best Answer11-08-2017 05:44
11-08-2017 05:44
Weather app works at home so must be WiFi issue???
Best Answer11-08-2017 05:47
11-08-2017 05:47
@Tom.han63 wrote:Weather app works at home so must be WiFi issue???
That is correct, @Tom.han63
Best Answer11-08-2017 06:11
11-08-2017 06:11
Does WiFi connection work only at home network where i initially set up my device? My messages and weather apps no longer work so thinking this must be the issue. How do disconnect WiFi so ionic syncs only through Bluetooth?
Best Answer11-08-2017 06:15
11-08-2017 06:15
@Tom.han63, you can use the Fitbit app Device Settings for WiFi to add/save additional networks, then when you are in range of a saved network it will connect to it.
11-08-2017 06:15
Not necessarily. I am at work with no WIFI, but I have a 4GLTE connection and my weather app updates whenever I sync with my phone.
Best Answer11-08-2017 06:40
11-08-2017 06:40
So how do I set the ionic to only pair via Bluetooth?
11-15-2017 06:52
11-15-2017 06:52
Just a quick update on the weather app...after traveling across the country the app never did show the current location. The two locations I manually entered updated regularly. The current location feature needs work.
Best Answer11-15-2017 07:53
11-15-2017 07:53
Strange. When I am at work, it shows the city I am in. When at home it shows that city. Updates without me changing a thing.
Best Answer11-15-2017 08:54
11-15-2017 08:54
@SunsetRunner wrote:Strange. When I am at work, it shows the city I am in. When at home it shows that city. Updates without me changing a thing.
Ditto
Best Answer11-15-2017 10:45
11-15-2017 10:45
Have you loaded the accuweathwr app on your phone?
Best Answer11-15-2017 11:02
11-15-2017 11:02
@Tom.han63 wrote:Have you loaded the accuweathwr app on your phone?
Nope. I have a widget, but it's The Weather Channel.
I do have Location settings on and set to High Accuracy. Also, I can see Fitibit is listed as requesting location, so I know it's looking to see where I am.
Best Answer11-16-2017 15:06
11-16-2017 15:06
