09-10-2018
08:41
09:28
09-10-2018
08:41
09:28
My Ionic can charge overnight but by the middle of the next day, 70% is gone.
it used to go 4-5 days before I had to recharge. I have restarted it & my phone, synced them, tried to update-none were available, and looked for anything running continuously. I also keep it clean. Nothing has worked. Help!
09-10-2018 09:12
09-10-2018 09:12
At this point, it is better to contact support.
Just follow their instructions, try it, and reach back. If it isn't a clock face draining the battery, most likely it will be replaced.
09-10-2018 09:36 - edited 04-22-2024 06:01
Welcome to the Fitbit Community @Lorimccar, hope you're doing great! Thanks for already troubleshooting this inconvenience with your Ionic's battery life.
The length of time your Fitbit device operates on a full charge depends on how frequently you use it and various settings. This article provides battery life estimates and tips for turning off features you don't need when you want to prioritize battery life.
If your phone is running the Android 8 operating system, you may see a notification letting you know the Fitbit app is using battery resources. For more information, see Why is the Fitbit app sending a notification to my Android phone?
The Fitbit Ionic battery can last up to 5 days. Because battery life is affected by use and other settings, actual results may vary. Consider these tips when you want to conserve battery life:
If the battery is still draining too quickly, I'd recommend getting in touch with our Customer Support Team like @SunsetRunner suggested.
08-01-2019 12:24
08-01-2019 12:24
Having the same issues but out of warranty. I just wanted to say with the greatest respect, the advice being given makes no sense. What you're saying is that after people buy the ionic for its features they must then disable them all of they want the battery to last more than 6-8 hours. Seems the battery just gives up after a year and is then no good. Love my ionic but wont be buying another for this reason
