11-26-2018 03:38
11-26-2018 03:38
My Ionic doesn't seem to be able to move past the pin screen. Pressing any button or swiping in any direction brings up the pin input screen, but even entering the pin has no effect. I am unable to see steps, get to the exercise screen or do any function. However, on the app, steps are recorded as is sleep active minutes etc. The wallet also still works. Any one else have a similar issue?
11-26-2018 04:24
11-26-2018 04:24
Have you tried looking at the following help article regarding device lock?
11-27-2018 19:03
11-27-2018 19:03
Hello @MustangB, it's good to see you visiting the forums for the first time, welcome.
Thank you for your question regarding the pin screen you mentioned. Please let us know if you're able get pass this screen with the steps @N8teGee mentioned previously; this should be of help get you back on track.
Please keep us posted.
11-28-2018 23:08
11-28-2018 23:08
11-28-2018 23:10
11-28-2018 23:10
11-30-2018 15:23
11-30-2018 15:23
Thank you for your reply @MustangB, I've seen that other users where able to access their phone's pin code to unlock the Ionic's display when they're using and Android device, could you please try this option and check if you're able to unlock it? Then try following the steps mentioned previously to disable this function.
Keep us posted.
11-30-2018 16:14
11-30-2018 16:14
12-04-2018 13:10
12-04-2018 13:10
Thank you for your response and all details provided @MustangB, I've gone ahead and sent your information to the Customer Support team for further assistance, so you should be getting a reply soon.
Keep us posted on the outcome.
12-06-2018 14:42
12-06-2018 14:42
12-07-2018 18:04
