09-07-2018
07:41
06:09
09-07-2018
07:41
06:09
I've had so many issues keeping my iconic synced to my phone. It's getting incredibly frustrating. I fixed it the first time using every tip and trick I could find but this time it's even more screwed up. Not only will it not connect to my phone(android) but now it's telling me that its Thursday 8:51pm when in reality its Friday 10:38am. I'm growing more and more impatient with this overly expensive watch that now can't even tell the time correctly. When it was working it was also VERY off tracking my runs. I've ran the same route for 4 years and know exactly how long it is and have tracked it with my car and also my phone and both have confirmed the exact distance. However, the lovely iconic is about .15miles off. I've tried fixing my stride length and that didn't help either
09-09-2018 06:12
09-09-2018 06:12
Welcome on board @Tmcgale776! Thanks for already troubleshooting this inconvenience between your Ionic and your Android phone.
While reading your post, my first thought is that your Ionic might be no longer paired to your Fitbit account and that's why it's not syncing or connecting to your phone's Bluetooth. In order to solve this, please go to the Bluetooth settings on your phone and remove the tracker. In the list of Bluetooth devices you'll see the Ionic and next to it, this symbol "!". Hit the symbol and it will take you to the next step, once you're there select the option that says "Forget this device".
Once you've made sure about that, go back to the Fitbit app, go to the "Account" option in the upper right corner and select "Set up a Device". This should start the setup process for your device. ![]()
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements below:
If you're still unable to set up, try these troubleshooting steps:
Hope this helps, keep me in the loop!
Best Answer06-20-2019 06:18
06-20-2019 06:18
So I have upgraded my phone to the Samsung S10+, which doesn't appear to be in the list od supported devices. Is there an update or.. I love the idea of this watch and the look.. But it is literally a very expensive watch. I cant connect at all. Ive tried all the tricks, now I guess I know why. HELP!!
