10-02-2017
06:17
08:51
10-02-2017
06:17
08:51
After over 48 hours of these fruitless attempts to sync my Ionic is sitting here on my desk vibrating away with a blank face
I can't get it to stop
Best Answer10-02-2017 07:41
10-02-2017 07:41
Hey there @suesaroo22, thanks for stopping by! This is very strange my friend.
First of all, I'd recommend leaving your tracker charging around 2 hours just to be completely sure it has enough power to be on. Then, please try restarting it by following these steps:
I you are able to turn it on after those steps, please make sure the firmware is updated on version 27.25.16.7.
Give this a go and let me know how it goes!
10-02-2017 08:32
10-02-2017 08:32
It did stop vibrating.
Here's my story
I've been attempting to sync and download the update for over 48 hours and nothing is working.
I have followed every piece of advice in every post on here.
It won't recognize wifi or Bluetooth
I've removed every Bluetooth device and reset Bluetooth on my phone and reset the Ionic
my phone is an (iPhone 6)
I've deleted and reinstalled the fitbit app
I've deleted the Ionic from the app and Bluetooth, it's not connecting to any of my other devices via Bluetooth (I've checked that to make sure there's no conflict)
I've paired and repaired the device 3 times now and it still won't sync completely.
I cannot access clock face or apps and the Ionic randomly goes dark and doesn't log steps etc.
10-02-2017 08:35
10-02-2017 08:35
and.... now I have the same error message I have been getting for the last 2 days
FBBluetoothErrorDomainerror 8.
10-02-2017 08:49 - edited 10-02-2017 08:50
Thanks for getting back to me @suesaroo22. Well, here we go once more (don't give up, I got your back!
Sometimes the Fitbit app is unresponsive after you navigate to the Wi-FI setup screen. To fix this issue:
If you're getting "Can't find device" error:
Now, let's troubleshooting the WiFi:
Apps on your Fitbit watch update automatically over Bluetooth and Wi-Fi as needed. When an update over Wi-Fi is in progress, the downloads icon appears on your watch’s shortcuts screen (swipe right from the clock).
I'm here, keep me posted!
Best Answer10-02-2017 09:22
10-02-2017 09:22
Make sure the Ionic is charged to at least 25% before connecting to Wi-Fi:
At approximately 25% battery charge, Wi-Fi does not work on Ionic. Ionic is charged to 100% and has been all morning I had it charging overnight
10-03-2017 06:54
10-03-2017 06:54
Me again - still no luck, batteries full and it syncs to the app but....
I'm still stuck on version 25.9.19 and neither wifi or Bluetooth will allow me to download the update
when I connect to wifi it says it doesn't recognize the device
when I connect to Bluetooth it runs for a bit then fails
I have always been successful downloading updates thru Bluetooth
I have had a number of the fitbit devices
It won't recognize either wifi or Bluetooth and I'm frustrated. I've been working on this since Saturday
Right now my Ionic does nothing more than my Charge 2 with better graphics, no music, no apps, no custom clock face
Best Answer10-04-2017 08:59
10-04-2017 08:59
I have removed the Ionic from my app and am just packing it back into the box.
I'll check back in a week or so but, for now I have to give up.
Best Answer09-23-2018 07:14
09-23-2018 07:14
My ionic has done all updates and will connect to my bluetooth for about 3 minutes, then disconnects. I have restarted the device, along with my phone. This is the same issue I had with the Versa and I sent it back for a refund. Any way to get the device to connect and stay connected? This is frustrating. Thank you
Best Answer09-11-2019 09:29
09-11-2019 09:29
With all these complaints, surely Fitbit must admit their product is faulty. Your advice doesnt work and there is a problem.Please fix!
11-14-2019 15:10
11-14-2019 15:10
Getting absolutely sick of my fitbit ionic. After syncing issues it seemed to get sorted. However it's now over a week of turning on/off phone, fitbit, Bluetooth nothing works. Very frustrating, tech should work
Best Answer12-13-2019 12:20
12-13-2019 12:20
My Ionic syncs to my iPhone, but not my Mac. I have followed a number of forum suggestions and still nothing.
Mac is using version 10.13.8 (older Mac)
iPhone is using version 13.3
I have turned on and off the Bluetooths and all my devices in my home. I tried to sync at different times of the day. Still nothing.
Any other suggestions?
Best Answer12-23-2019 00:38
12-23-2019 00:38
Ionic fitbit has endless problems connecting I have followed all the advice in the forms and still might connect to the phone worst pitch ever if you're thinking about buying an ionic Fitbit make sure you read all the forms and all the problems people have with connections after 2 weeks of trying everything suggested my ionic still doesn't count steps what a waste of money I'll never buy another Fitbit again
12-23-2019 04:31
12-23-2019 04:31
Best Answer12-29-2019 10:11
12-29-2019 10:11
Yep - same here
Tried everything - apart from putting the stupid waste of time in the bin
Why do fitbit not comment and sort this issue out?????
Best Answer12-29-2019 23:37
12-29-2019 23:37
Best Answer05-15-2020 21:59
05-15-2020 21:59
No your post was not helpful. My ionic hasn't synced with the app since May 16th at 6:15AM!! More than just a little frustrated. It worked fine before the last firmware update.
Now, neither my Galaxy Note 5 nor my Tab S6 (both Samsung) can make a Bluetooth connection. I've tried "all" of your suggestions. Nothing works.
Sounds like Fitbit is about to lose a whole lot of Android people. I've wasted half the evening at this. Not too happy right now.
