07-15-2021 10:39 - last edited on 07-15-2021 18:37 by LiliyaFitbit
My Ionic is displaying a big red X and a message, "Data not cleared. Sync & try again". However, it will not sync. 🤔
Best Answer07-15-2021 18:36
07-15-2021 18:36
Welcome to the Fitbit Community, @IMMIKED.
Thanks for the details shared in your post. I understand how you are feeling and recommend doing the following:
1. Connect your watch to the charging cable.
2. Confirm that your Fitbit app is updated to the latest version: How do I update the Fitbit app?
3. Restart your phone and open the Fitbit app.
4. Tap the Today tab, and tap your profile picture.
5. Tap Set up a device (Once you select the device you are setting up, it will give you the option to replace, go ahead and select it.)
6. Follow the on-screen instructions to continue.
Hope this helps.
