12-14-2020 23:33 - last edited on 12-16-2020 19:17 by LiliyaFitbit
I went for a swim, and my fit bit ionic began vibrating and turned off fully.
i initially thought it was a dead battery however it is not turning on after a significant amount of time being on charge.
I have tried the factory reset with the 3 buttons and nothing works.
There is no response on the screen nor is the heart rate tracker flashing.
Was my fitbit damaged from the water? I thought it was water resistant?
Is there something i can do to fix it?
12-15-2020 13:24
12-15-2020 13:24
Yep!
Do a thread search on this issue. Hopefully your Fitbit is still under warranty?
If so, contact support immediately. If you get a replacement, don't swim (or shower) with it.
No Warranty? Still contact support and have a cordial discussion with them.
Goodluck!.
