03-05-2019 08:47
03-05-2019 08:47
Can someone please help me? My watch won't turn on when I turn my wrist to look at it. It used to but doesn't anymore and I never changed anything. I'm at a loss 😞
Thank you
03-05-2019 10:17
03-05-2019 10:17
Sometimes the setting gets turned off unknowingly. Do a long push to left button which brings up the screen awake setting and make sure it is set to Auto.
03-05-2019 10:17
03-05-2019 10:17
03-05-2019 10:21
03-05-2019 10:21
You are awesome! It worked! Thank you so much 🙂
03-05-2019 10:21
03-05-2019 10:21
03-05-2019 13:51
03-05-2019 13:51
You're very welcome. Glad I could help.
03-17-2019 19:07
03-17-2019 19:07
i do a long push on the left button but there is no screen that shows on/off selection
03-17-2019 19:53
03-17-2019 19:53
@pasoupWhat comes up when you long press the left button?
03-17-2019 20:10
03-17-2019 20:10
I did the long push on the left as someone else suggested. It worked. Thank you so much.
03-17-2019 20:11
03-17-2019 20:11
I don't remember but I did the long push on the left button and it worked. Thank you so much.
03-17-2019 20:42
03-18-2019 04:58
03-18-2019 04:58
pasoup, try swiping left or right after the push brings up whatever screen.
03-18-2019 05:10
03-18-2019 05:10
03-18-2019 07:24
03-18-2019 07:24
Thank you,that fixes it 😊
05-29-2019 01:19
05-29-2019 01:19
Thank you for this tip it's working now.
07-17-2019 12:05
07-17-2019 12:05
Thanks for submitting that solution!
09-04-2019 09:05
09-04-2019 09:05
Thanks for the solution it really workEd
