02-24-2021
02:29
15:37
RicardoFitbit
02-24-2021
02:29
15:37
RicardoFitbit
Ok so I posted a few days ago how disappointed I am with the ionic over the blaze, heart rate readings and battery life mainly and not tracking sleep. After numerous attempts at soft shutdowns, Bluetooth on/off, log out and turn heart rate off/ on. I decided to do a factory shutdown so I could re install. Now I can't turn on...at all. Help!
02-24-2021
15:37
09:35
02-24-2021
15:37
09:35
Hello @Steely70, your participation here in the Community Forums is appreciated.
Thanks for bringing this to our attention and for the details that were shared, your effort troubleshooting your device before posting over here is also appreciated. To better assist you with this, can you please let me know if the heart rate sensors are flashing or is your device completely unresponsive? If you haven't already done so, I recommend you to check our help article: Why isn't my battery charging on my Fitbit device? and let me know how it goes. Such article includes a restart process which can be really helpful for this situation.
Looking forward to your reply.
Best Answer02-24-2021 20:08
02-24-2021 20:08
Best Answer02-25-2021 04:45 - edited 02-25-2021 04:47
I am having problems too - But addressing your own. Have you tried holding all three buttons
down at the same time?? I'm sure you have.... But, hold the buttons down for a greater time up
to a minute - you may be lucky to get the blue Fitbit icon come up. Try it with the charger connected too.
I had this problem at one time and it worked for me. It's got to be at least 1/2 a minute or more for it to work
on a seemingly dead watch. Good luck
Best Answer02-25-2021 05:19
02-25-2021 05:19
Best Answer02-26-2021 06:35
02-26-2021 06:35
