04-15-2019 04:42
04-15-2019 04:42
Best Answer04-15-2019 05:18
04-15-2019 05:18
If you go to the clock face, you can hold the button on the left side. If music comes up then swipe right and the setting should be "Screen wake", set that to "Auto" and you should be good 👍
Best Answer04-15-2019 09:50
04-15-2019 09:50
Depending on the ionic version, you may see the pin for fitbit pay, it would then bee swipe left for quick settings. This is all explained I the user manual, click the help link below, ionic, user manual.
