08-11-2020 10:01
08-11-2020 10:01
my ionic died this morning, i plugged it in and nothing happens no battery indicator, etc. i took it into work and plugged into my laptop, then the wall charger, then the car charger, nothing still. i tried performing a soft reset (left and bottom right bottom for 20s) no luck, tried performing a hard reset (all 3 buttons 20-30s) no response. for awhile every once in a while the logo would flash for a split second, i haven't noticed that happening the last couple hours. i chatted with fitbit "support" and explained this and that i thought it was a software/firmware related issue and got the usual disappointing line about getting a 35% off discount on another fitbit (why would i continue to buy products that dont work?).
so here's the deal prior to giving up on Fitbit and going to a apple watch, does anyone have any other things i can try to fix this thing? im honestly amazed that fitbit still hasn't come up with a fix for these ionic's being their flagship watch.
08-11-2020 11:23
08-11-2020 11:23
On 2 nd watch in 2 months and can’t get it changing at all. Tried everything get very frustrated
Best Answer08-11-2020 17:44
08-11-2020 17:44
As silly as this seems, it worked for me- clean the charging contacts on the back of the watch. Use a small knife or flathead screwdriver and gently scrape. I then put the charging cable back on, and it started charging again.
Best Answer08-11-2020 19:08
08-11-2020 19:08
Mine was working fine until 11 PM last night when it just went to blinking the Fitbit logo. I've tried all the restart directions but it doesn't do anything.
08-11-2020 19:40
08-11-2020 19:40
Thanks for the advice I should have mentioned that I tried this as well on both the device and charger but thanks for the input
08-12-2020 07:28
08-12-2020 07:28
Mine has also shut down today and will not come back on.
I have reported to fitbit support services
