Hi the battery on my fitbit ran out and when i try and charge it nothing happens. The screen wont switch on. I have tried all the tips on the internet, ike pressing the buttons, leaving it plugged in to charge for a while but nothing happens. It is completely unresponsive.
@Midge06 Sorry to hear you are experiencing problems. I would take a look at the charging pins on the back and give them a good clean with a soft toothbrush and some rubbing alcohol and dry off with a soft lint free cloth. There also some troubleshooting pointers on charging. If this still does not help, you will need to. contact customer support so they can assist you further.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
