12-20-2017 04:04
12-20-2017 04:04
I just got an ionic fit bit. On the second day, the little metal piece at the end of the wristband fell out. I put it back in the only way that seems possible, but cannot clasp my watch close without considerable force. How can I fix this?
Best Answer12-20-2017 05:49
12-20-2017 05:49
Best Answer12-20-2017 04:07
12-20-2017 04:07
Hi @JennyInNJ - You posted this in the Charge 2 forum. I will move this thread to the Ionic board. Good luck!
Best Answer12-20-2017 05:14
12-20-2017 05:14
@JennyInNJ wrote:I just got an ionic fit bit. On the second day, the little metal piece at the end of the wristband fell out. I put it back in the only way that seems possible, but cannot clasp my watch close without considerable force. How can I fix this?
@JennyInNJ assuming the metal bit is in the right way, ie Fitbit logo on the outside, small bit on the inside (I don't think it will go in the wrong way) it's just a case of lining up the nub with a hole. It can seem a bit of a push if not perfectly lined up but it does get easier with wear.
12-20-2017 05:49
