06-09-2021 07:48 - last edited on 06-13-2021 12:11 by LiliyaFitbit
hi
I bought new straps for the Fitbit iconic but I am having issues removing the current straps to put the new ones on.
One side of the strap is removed very easily. The other side is impossible to remove. It does not appear to be spring loaded when you press it down so it stays down. The other side is spring loaded. When you try to press the release catch it is different from the other side and already pressed down.
Has anyone got any solutions to remove the strap not coming off?
Thanks
Best AnswerWelcome to the Fitbit Community, @Steph20212.
Thanks for the details shared in your post and for already trying to resolve the issue. I recommend confirming the steps to change the band in How do I change the band on my Fitbit device? If the issue persists, please get in touch with our Support team so they can look deeper into the issue and help you with this matter. Click here to get connected with them via chat or phone.
See you around.
