12-16-2018
22:53
09:15
SilviaFitbit
12-16-2018
22:53
09:15
SilviaFitbit
I'm having trouble connecting my wireless dre beats to my ionic?!?! Help
Best AnswerGotta put your Beats in pairing mode and have one or more music playlists in your Ionic. If you do then ->
1 Tap the Settings App
2 Tap Bluetooth Connection Options
3 Tap + Audio Device
4 Your Ionic will Search and find your Beats
5 Tap Beats to pair
6 Then go into the Music App
7 Tap the Playlist you want
8 Music should play thru your Beats if they are Connected
Try it. See if this works for you. Chk your Beats how to put them in pairing mode. Usually it is holding down the Power button for a few seconds until the light flashes.
A warm welcome to the Community @Inessaisme. I would like you to make sure that you've tried these steps to properly connect your Ionic and the Wireless Dre Beats How do I connect Bluetooth audio devices to my Fitbit watch?.
Thanks for your advice @Whistler888.
