I'm not able to sync the Ionic with my Iphone 7. When I check the list of devices, the app is always looking for the ionic. I already tried restarting my cell phone, turning off/on bluetooth, etc. When I remove the device from my bluetooth preferences and try to pair it again I get the message "connecting to device" but nothing happens. The only solution is to reset the ionic to factory preferences but I'm losing all my data. How is it possible? What is the point to buy a device like this if I'm going to lose all the data from time to time?
Please help!
Welcome to the Fitbit Community @GermanCo! Thanks for already troubleshooting this syncing issue with your Ionic. Nice way to go!
I know this can be a little annoying my friend, but I'd like you to please check and review this post where my friend @mrmath3 share a list of steps to sort this out. Many of them you've tried already, but it won't hurt to double check and make sure none of them have been skipped.
Also, you can use the following workaround:
All data that Ionic tracks is saved on device and once you're able to sync, it will save it to your account for your viewing.
Give this a go and let me know the outcome, I'll be around!
