10-01-2017
21:17
20:11
DavideFitbit
10-01-2017
21:17
20:11
DavideFitbit
Hello,
I am relatively new in the forums.
I am having some problems with Bluetooth music syncing in and out while I am running. anyone have similar problems? I have the jaybird freedom if that helps.
Moderator edit: format
Best Answer10-02-2017 09:46
10-02-2017 09:46
It's great to have you here @soguilk! I would like you to double check that Ionic and your Bluetooth headphones are properly connecting by following this procedure How do I connect Bluetooth audio devices to my Fitbit watch?. Also, you can restart your tracker.
Hope this helps!
Best Answer10-02-2017 10:41
10-02-2017 10:41
I recommend restarting the phone and the Ionic at the same time and see if that helps.
10-02-2017 22:16
10-02-2017 22:16
Working better now! The restart on both device helped. Thank you
