01-21-2018 08:10
01-21-2018 08:10
I try to add Kathmandu Nepal to set up weather but Kathmandu is not listed in the database. we have many who uses your product so i really appreciate if you add Kathmandu Nepal in your database so we can use weather functionality.
Thanks.
Best Answer01-21-2018 09:50 - edited 01-21-2018 09:52
@damauli wrote:I try to add Kathmandu Nepal to set up weather but Kathmandu is not listed in the database. we have many who uses your product so i really appreciate if you add Kathmandu Nepal in your database so we can use weather functionality.
Thanks.
@damauli I’ve just checked and it is listed, as you can see in the screenshot I took. Sometimes searching for cities can be a slow process, so have another go at adding it.
