08-24-2021 15:09
08-24-2021 15:09
I have two Fitbit devices I use depending upon the task, specifically an Ionic and a Surge. Recently my Ionic ran completely out of power and I had to recharge it fresh (I went on a bike trip and found I had no charging cable with). Since then, only my Surge will show live updates to my stats on the app, and the app tries to sync the Surge ahead of the Ionic. My Ionic is my main watch, and the one I want giving live updates. How do I make it the priority tracker?
I have searched the support forums for an answer, but nothing quite matches. I also did not want to do anything irreversible before asking for help.
Best Answer08-24-2021 15:26
08-24-2021 15:26
I'm just guessing here, but maybe get the Surge out of bluetooth range, then sync. Hopefully it will sync with Ionic and keep updating from there. At least shouldn't do any harm to try.
Best Answer08-30-2021 13:09
08-30-2021 13:09
Hi JohnnyRow,
Thanks for responding. Fitbit keeps trying to sync the surge first even when I am out of range. What's funny is that there was one point where the ionic was the primary even when the surge was nearby. I'm not sure why or how to replicate that. It's gone back to making surge the primary, but my current plan is to let the surge run out of battery power and see if that makes a difference.
