07-08-2020 02:14
07-08-2020 02:14
After a pool swim, watch got very hot, lost all battery charge & vibrated consistently. Recharged successfully. However, after several months & multiple resets, still no heart rate information, battery now fully spent within 24 hours (& less when tracking exercise) &, at 8pm every night, seeks to calibrate but fails. What can I do?
07-09-2020
13:38
08:00
07-09-2020
13:38
08:00
@Traceyjo89 A warm welcome to the Community. Thanks for getting in touch about this.
I appreciate the detailed information shared. I would like you to follow these tips to extend your Ionic's battery life. Since you mentioned that you're receiving a calibration message, please do the following:
- Plug your Ionic and setting it on a flat surface
- Restart your watch or shutting down (and turning it back on)
- Once the calibration has been completed, a green check mark will appear
Let me know the outcome. I'll be around if you have any additional questions.
07-11-2020 22:36
07-11-2020 22:36
Thanks @SilviaFitbit. I have previously tried all the tips to extend battery life and also multiple restarts and shutdowns. However, I gave them all another try following your reply.
Unfortunately, battery life remains poor, the watch is not recording or reporting heart rate data and I continue to get a calibration error. I think that the battery had a problem and this has "fried" the workings of the Fitbit. The watch is only 18 months old and the battery problem occurred at 14 months so I'll be an unhappy customer if this can't be resolved.
Any other advice appreciated.
07-14-2020
16:23
08:00
07-14-2020
16:23
08:00
@Traceyjo89 Thanks for getting back. I appreciate that you followed the troubleshooting provided.
In this case, I've shared your post with our Support team and someone will reply to you as soon as possible. Keep in mind that due to recent events affecting our operations, we might take a bit longer to get back to you.
07-25-2020 04:37
07-25-2020 04:37
Exactly same issue with my ionic, it started with heart rate sensor not working, had to reset the watch and now the battery drains in few hours and this calibration message keeps coming and failing to calibrate
07-29-2020
17:00
08:00
07-29-2020
17:00
08:00
@Manvinder Welcome to the Community. I appreciate the troubleshooting tried prior to posting.
I've shared your post with our team and they mentioned that you already have a case with them, please continue the communication through email, they'll be happy to continue assisting you.
07-29-2020 19:55
07-29-2020 19:55
I’m having what seems to be the start of the same problem. Odd vibrations, heart rate monitor intermittently not working, steps intermittently not being tracked... about 2 years old. Tried all the restating maneuvers. Is this repairable, get a new Fitbit, or maybe jump to another Mary watch? Apple??
07-30-2020 03:08
07-30-2020 03:08
Since two weeks the watch shows unreal excercise stats and this week after a full recharge the battery died and I cannot recharge it. Resetting does not work either. Please advice. I trust there is better solution than buying a new one.
07-31-2020
13:18
08:00
07-31-2020
13:18
08:00
@DoctorLeuth @Aloys61 A warm welcome to the Community. Thanks for getting in touch about this.
@DoctorLeuth I've shared your post with our Support team and they mentioned that you already have a case with them, please continue the communication through email, they'll be happy to continue assisting you.
@Aloys61 Thanks for the troubleshooting tried prior to posting. Since your Ionic isn't charging, please follow the tips on this article.
