08-04-2018 16:58
08-04-2018 16:58
Blue tooth syncing of activity of Ionic is coming ridiculous - at first I thought it was fix with a replacement - but now activity only appear to work if I shut the Ionic down and restart and also most of time need to restart the device - which is a Galaxy Tab S3 - I have a Note 8 but with flakiness of Ionic syncing, I don't want it on my phone.
Knowing that Blue-Tooth is low power and wi-fi is more taxing, here is a solution - have a manual button on the Ionic to fire off a sync on Ionic - and also button on device - and sync information using the wi-fi network.
One thing if Samsung comes up with Gear watch - hopefully S4 - that has REM sleep detection and stages of sleep detection, Ionic and Fit bit - will be gone from me - primary because of this issue.
Best Answer08-05-2018 02:09
08-05-2018 02:09
I think the problem you are having is related, at least in part, to your tablet, which is not on the Supported devices list. I have a tab S2 (also not supported) and though it works, syncing with the Ionic and Versa is rather flakey (tho it works fine for my flex 2 and Alta HR). I see your phone IS supported so syncing may well work better on that device. Why not give that one a go and it might solve your problems. My supported phone (S8) works much better than the tablet with the smart watches.
Helen | Western Australia
Best Answer08-05-2018 02:47 - edited 08-05-2018 03:36
i have ironic and samsung 7 the sync has become a joke i spent all yesterday uninstalling and reinstalling
the app to no avail I even had two chat sessions and ended up taking the ironic back to factory settings
again to no avail i presume it was because firmware was automatically updated i have gone back to my flex which seems to be ok at the moment 10 hrs of my life yesterday i can`t get back Samsung for me now and i will be warning people off fitbit
Best Answer08-06-2018 14:39
08-06-2018 14:39
@henry1948the S7 should work with the Ionic.
Steps I would do
Check for Fitbit app updates.
Restart tracker
Restart phone
Remove the tracker from the phones Bluetooth menu
Now try to sync the tracker.
Or set it up if it was removed from the account.
