Missing Battery % on newest Firmware upgrade
ANSWERED
Were is the Battery % status on the new Android (Firmware Version: 27.32.10.15)?  I have looked everywhere and it is not on the same Notifications (on/off) / Wake Screen as before or any other I can find.
I get the 25% battery left email notification but cannot check the Ionic Fitbit battery life remaining other than online or the mobile app that says High, Medium or Low only.
Fitbit needs to fix this if it was deleted.
1 BEST ANSWER
Accepted Solutions
@TomG4073 If you swipe up from your main Ionic screen you will see your current battery level displayed in  the top left of Fitbit Today. Hope this answers your question
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
7 REPLIES 7
it's in the Fitbit Today thing. swipe up.
for me, it's on the main clock since the watch face I use has it there.
Tony | UK
Thanks. I use the clockface with the heartmonitor always showing and it is
not on this one and I cannot swipe to bring it up but I did find it in the
Today's Activity at the top left.
I appreciate your help.
I had to reset my Ionic because it was not allowing me to swipe up but your solution is correct.
@TomG4073 Good to hear the reset worked. If your screen continues to freeze get it logged with Customer Support and they will look into it for you, if need be you can use the link below.
http://help.fitbit.com/?cu=1
@wizll also gave the correct solution before I had finished posting my reply.
Tony | UK
Very helpful, thanks again.
FYI: the LCARRs (trek) watchface has battery, heart rate, steps, date/time and temperature. No charge.
