03-16-2018 02:11
03-16-2018 02:11
The little lock has fallen out of my band. Can you buy this separate or will I have to get the entire band?
Best Answer03-16-2018 02:21
03-16-2018 02:21
You will have to replace the band. If it is under warantee Support will do it for free (link in my signature )
Helen | Western Australia
Best Answer03-16-2018 11:08
03-16-2018 11:08
@James1701wrote:The little lock has fallen out of my band. Can you buy this separate or will I have to get the entire band?
Do you still have the spare band that came with your Ionic? If so you could always take the part out of that and fit it to the band you use.
