01-06-2018 16:20
01-06-2018 16:20
My Fitbit would always light up when I raised my arm, but after a week it has stopped doing it and I need to press the side bottom to make the clock face light up.
How can I make this function work again ?
01-06-2018 16:39
01-06-2018 16:39
Please swipe right on the clock screen. You should see the Screen Awake option.
Make sure it is set on Auto
Let us know how this goes.
06-10-2018 10:38
06-10-2018 10:38
I have fitbit charge 2 and it was working fine yesterday but now on arms up it is not showing time. There is no change in setting kindly help
Best Answer09-20-2018 12:05
09-20-2018 12:05
I can’t get mine to open up that screen
Best Answer09-20-2018 12:23
09-20-2018 12:59
09-20-2018 12:59
Best Answer11-10-2018 00:14
11-10-2018 00:14
I had this same problem. Thank you, your advice worked perfectly!
Best Answer03-25-2019 16:04
03-25-2019 16:04
Perfect worked for my Versa. Thank you
Best Answer11-13-2019 15:31
11-13-2019 15:31
My Fitbit will not show time when I lift my wrist up
Best Answer10-01-2020 15:30
10-01-2020 15:30
I have a Charge 4. There is no “Awake” function when I scan right or left.
Best Answer01-06-2023 11:54
01-06-2023 11:54
Thank you it works!!!!!
