08-31-2020 05:16
08-31-2020 05:16
I factory rest my iconic classic any its not turning on. The logo blinked on the watch screen for almost half an hour. I have tried presing all the sequences buttons but nothing happening. Please guied.
Best Answer08-31-2020 05:20
08-31-2020 05:20
The long and short of it is as follows...
1. If you have a faulty device, like most of us do, you need to contact support and hope you’re under warranty. If you’re under warranty, you stand some chance of getting a device replacement. The support simply tell you to factory rest the device again and hope for the best. If that fails, you might get sent a replacement.
2. If you’re out of warranty, you’re going to get a discount at best. A discount on another device that will fail in time, and then repeat the circle of frustrating Fitbit life...
Good luck!
Best Answer08-31-2020 05:39
08-31-2020 05:39
Yes am out of warranty. It shows no sign of life! Just nothing. I tried factory reset an now nothings happening. Its frustrating
Best Answer08-31-2020 06:16
08-31-2020 06:16
Sounds you’re out of luck then sadly, unless you get a customer support representative who is feeling generous and will send you a new or refurbished device out of pity.
If they don’t do that, best you’ll get is a discount to buy a new device which will eventually fail like this.
