04-17-2020 23:26 - edited 04-18-2020 00:10
I did factory reset in the screen for my Ionic and after that it keep showing the fitbit icon with the massage "Hi get started set up www.fitbit/setup" in all the languages. I have no idea what i should to do.... Is anyone can help would be appreciate. 😭
Best Answer04-18-2020 12:59
04-18-2020 12:59
@YuriAkatee, that indicates that you must use the app to re-add the Ionic back to your account. In the app, select the Account screen, then select Set Up a Device, and follow the on-screen instructions to add the Icon back to your account.
04-18-2020 12:59
04-18-2020 12:59
04-18-2020 14:14 - edited 04-18-2020 14:20
Thank you so much for the advice and now i can get my Ionic back But seem like there is a problem when i try to reset my Ionic bcuz the watch itself already restart but my app still try to connecting with the watch (stage 1 of3) which ending with they can't connected. Now the tracker seem like not working like track my step but heart rate is okay. And i can't change the clock faces bcuz when i try the page in the app keep loading and not showing anything. So In this case what should i do?
