04-20-2018
09:44
06:40
04-20-2018
09:44
06:40
My Ionic heart rate monitor is waaaay off when I work out. As soon as I start running, it immediately jumps to 160-180, when my actual heart rate (measured either manually or with another device like the treadmill heart rate monitor) is actually closer to 110. This happens every single time I run.
Aside from this it appears to work normally (though it reads about 10% higher than my manual reads). The funny thing is that my old Surge developed exactly the same problem when it was about 18 months old (it had worked perfectly until then, but then started giving crazy heart rate readings when I exercised).
Has anyone experienced a similar problem?
05-18-2019 10:28
05-18-2019 10:28
05-18-2019 15:34
05-18-2019 15:34
05-21-2019 08:06
05-21-2019 08:06
Many thanks for getting back @Davidfernan85 and @Wilf18.
We really appreciate your feedback. Our team is always looking to improve the Fitbit experience and is always working towards.
I'll be around if you need anything else!
09-11-2019 23:31
09-11-2019 23:31
Is there any update on this? Mine is the same.. for the first 5-10 mins of my 40 min run my heart reading is 190/192 then all of a sudden drops to 150-160 (though my pace is normally slower at the beginning).
Best Answer09-12-2019 00:35
09-12-2019 00:35
Best Answer09-12-2019 00:48
09-12-2019 00:48
Best Answer09-12-2019 02:03
09-12-2019 02:03
Best Answer09-12-2019 02:17
09-12-2019 02:17
I've been running for 4 years and recently had a full check up and ecg etc. I start running slowly and my ionic report 192bpm for 5 or so mins and then drops to 140 ish... I then increase my pace and it's up to 160 ish (which at the pace I'm running I'd probably expect). The bug is at the start of the run... it does it everytime (I've tried resets, factory resets, wearing it higher on my arm/wrist etc.) nothing. Not happy.. think a Garmin is going to be on my xmas wish list.
Best Answer09-12-2019 03:41
09-12-2019 03:41
Best Answer09-12-2019 03:44
09-12-2019 03:44
Best Answer09-12-2019 03:49
09-12-2019 03:49
Hi @Wilf18
so you're saying not all Ionics have this problem? So if I contact support they should be able to replace it? (it's less than 12 months old)?
Best Answer09-12-2019 06:57
09-12-2019 06:57
*UPDATE*
after reading many different things to try this morning I tried something different.
1. In settings (on my Ionic) I turned off Heart Rate monitoring
2. I reset my fitbit
3. I turned on my heart rate monitoring - but it wouldn't monitor. so I turned it off, waited 60 sec and then turned it on again - after 60 secs it started picking up my heart rate.
Today on my run I wore it 5cm higher than my wrist bone (I have tried this many times before) but 1 extra notch tighter.... and.... IT WORKED. My heart rate didn't jump to 192, but instead slowly rose to 155, 160, 162 on my run etc.
I'm running again tomorrow so I'll keep you all posted hope this helps somebody!
Best Answer09-12-2019 08:52
09-12-2019 08:52
Best Answer09-12-2019 09:05
09-12-2019 09:05
Best Answer09-13-2019 07:19
09-13-2019 07:19
Best Answer09-13-2019 07:48
09-13-2019 07:48
I ran again today and it was fine! I'm hoping has fixed it. Did you try the "turning the heart monitoring off" etc. I mentioned?
Best Answer09-13-2019 09:00
09-13-2019 09:00
Best Answer09-17-2019 12:07
09-17-2019 12:07
Hi everybody thanks for keep sharing your thoughts about this topic.
@RobIgoUK Thanks a million for sharing this amazing troubleshooting steps. Some users have reported good results with the steps suggested in this help article too.
We keep working on finding a solution for the rest of users reporting high heart rate while not performing high intensive activities.
I'll be around, let me know if you need anything else.
09-27-2019 15:34
09-27-2019 15:34
My heart rate monitor is hugely innacurate as soon as it starts on the running setting. It instantly jumps up to between 170 and 180 as soon as I start to run. However if I don’t enter the run mode and start to run it remains around 110. I’m very fit. I train every day and can’t understand what’s happening I thought the watch was faulty so I exchanged it. The new one was fine for the first 3 runs and then it started to do the same thing as the first one. If I measure my HR in my phone during this episode it is reading around 110 bpm. Has anyone experienced the same problem. Can anyone advise me. I have tried the watch on both wrists at different part of the wrist. I can usually get it to read accurately but I might have to stop and start multiple times. And even then it might just randomly jump up in the middle without me realizing.
Has anyone had a similar issue.
Best Answer09-27-2019 16:14
09-27-2019 16:14
