11-12-2017
16:05
11:54
SantiR
11-12-2017
16:05
11:54
SantiR
My ionic is not able to charge n it only 2 weeks old
Moderator Edit: Format
06-24-2018 06:59
06-24-2018 06:59
So glad things are working for you guys! I'm ready to throw mine out the window after only having it for 2days!!!
06-27-2018 22:50
06-27-2018 22:50
I had the same issue. I am not 100% what made it work, after trying various techniques for about a week. My final attempt before things were working was to unplug from a 2.1A charger and plug it into my laptop (lower amperage) for about 10 minutes and then go back to a 1A charger, things started to work for me. I believe it has to do with some weird high current crowbar by the design of the the Ionic. Try that and lets see.
06-29-2018 10:28
06-29-2018 10:28
07-03-2018 15:19
07-13-2018 18:04
07-13-2018 18:04
This is so true. I wish I could go back and buy an Apple Watch! I’ve had so many issues with the ionic.
07-15-2018 04:47
07-15-2018 04:47
07-26-2018 18:58
07-26-2018 18:58
This worked for mine !!
07-30-2018 02:50
07-30-2018 02:50
08-18-2018 11:04
08-18-2018 11:04
Thanks for the help.. my ionic started and came to life 💐💐💐
08-23-2018 15:18
08-23-2018 15:18
Mine also died, will not charge, no sign of life. Tried everything on this thread. My first Ionic was a complete lemon, never worked, and had to return it to the store after a day of wasting my time trying to get it to work. Purchased this one. It is now a few months old and won't turn on. Just got off the phone with them and they said it is under warranty and that they will replace it. So, I get to send my Ionic to them and THEN they will replace it after they check it out. Sounds like a process that takes a bit of time and also requires that my couple hundred dollar device gets to them and back without getting lost. Pretty frustrated. I like Fitbit, but at this point I have to consider switching to Apple watch.
08-23-2018 16:11
08-23-2018 16:11
10-27-2018 22:55
10-27-2018 22:55
I have same issue, two weeks old Ionic, battery went low, it turned itself off, got home, put it to charge, and nothing.
Tried reset and nothing.
following your steps now, hope it will work
11-02-2018 08:40
11-02-2018 08:40
I have tried this and it's still not working for me. Help please!
11-02-2018 10:47
11-02-2018 10:47
11-02-2018 11:15
11-02-2018 11:15
Thank you! I reached out to them this morning.
11-03-2018 02:08
11-03-2018 02:08
Tried it all, no signs of watch coming back alive at all.
11-12-2018 12:18
11-12-2018 12:18
The multiple reset you provided, It worked on mine.
This is a second Fitbit I have that is doing this. The first one, it was new, I submitted the case, and I got the replacement.
The replacement came in, and I was happy for three months. until I started to swim with the watch again. I maintained the watch with charge, and used it carefully. The claim Fitbit makes, the watch is water resistant is somewhat true. If you start swimming with it in an ocean, or highly chlorinated swimming pool, it is a matter of short time once you will see the charging problems. How the charging connector is designed, and the battery type and charging circuit, it will short something, it is a matter of time exposure in a harmful environment. The key to using it, washing in clean water, and avoiding swimming with it. Various pools where they chlorinate a lot, can damage it I think.
11-13-2018 11:53
11-13-2018 11:53
Hello everyone! Thanks for your continuous participation on this thread regarding Ionic not charging. Thanks for sharing your experiences and feedback on this thread.
If you haven't done so already; please try these tips to fix batteries that are not charging. This has helped other users in the past.
Keep me posted!
11-13-2018 11:59 - last edited on 02-27-2020 16:19 by LiliyaFitbit
Thanks for info.
I am supposed to get a replacement.
I had same problem with the blaze, was replaced once and when it broke for second time, they made it no more and up ionic came out.
I was hesitant to get it, but I lived my blaze so much, that I chose it over apple.
2 weeks only it lasted!, so disappointed!, I really cannot expected a lot more from ionic Fitbit.
Thanks for info..
11-14-2018 16:38
11-14-2018 16:38
